When it first starts up it squeals for a while, then sound good. Is it a belt problem or Bearing?
There is a small plastic T-Bearing at the rear/center of the drum that often wears that could cause the noise.
Easy to replace,but be sure to add a little grease to it before putting drum back in.
At times it could also be the front drum glides,or even the plastic Idler wheel.
Look closely at them all when you have the drum out.
All these parts are relatively cheap to purchase.
Wigo.
center of the drum
