SOURCE: there is no vacuum at the fuel pump. i replaced
Have you checked the fuel lines in the gas tank? Sometimes if the pickup line gets cracked it will **** air and no gas. give this a try. Good luck let me know.
Testimonial: "Thanks for the help"
SOURCE: I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
SOURCE: my indy 500 wont start i changed the fuel pump and
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
SOURCE: I have a 1992 polaris indy 500, it won't start
THE THROTTLE SAFETY SWITCH IS NOT WORKING, YOU CAN EITHER CUT THE WIRES OR REPLACE THE SWITCH. I SUGEST REPLACING THE SWITCH
SOURCE: I reringed a polaris indy
SOUNDS LIKE THE ENGINE IS BADLY FLOODED, SHUT YOUR GASS OFF AND REMOVE THE PLUGS, THAN PULL IT OVER UNTIL IT IS UNFLOODED. IT SOUNDS LIKE THE NEEDLES ARE STUCK IN YOUR CARBS
