I hooked up to use as computer moniter temoorariy and worked fine.when i returned to use as tv red light comes on but will not turn on with remote or manuel.I got dc power out of power board .Is there a reset or service mode to clear problem?
Since the tv is not turning on try unplugging it from the wall outlet for a few minutes. Up to 10 or 15 and see if the set will reset on it's own. If that does not work press the power button and when the front light comes on press and hold power button for about 10 seconds to see if it will reset this way. Maybe this work.
Does anyone have a fix? I have this same issue, and would really like to fix it. :/
This isn't a solution; but a question FUNKYDALLAS did you ever get you problem resolved? I have the same issue where I connected my computer via the VGA connection, and now the Polaroid TV will not power up, Red LED lights but when power-on via remote or manual button on side of tv pressed no BLUE light, I have unplugged the tv for hours and still not working, held the manual power button for ever still no luck, any suggestions?
