Reboot ur HDTV box buy unplug and replug is an hour later,see if get the color back.If not,than ur Sharp tv Main Tuner signal board is dead that the problems,must replaced the Tuner signal board to solved this problems.
Check the ventilation fins on the back. Sometimes they get obstructed with dust and then heat builds up. The TV then shuts down to protect itself from overheating. You can use a blow dryer to blow it out.
Examine the set with the color OFF and if No blue (odd problem) check hookup----component uses red, green and blue cables and if blue cable is bad and signal is from component on a box---box could be bad.
Easy way to know---hook DVD etc to a rear inputs= still no blue?
In the steup menu there should be a setting called "HUE" try adjusting that. If that does not work, you may have lost "green drive" circuits in your TV.
If the menu windows have the right colors, try playing a DVD or a video on it. If they look good you may have a problem with channel tuner or antenna.
Try a different AC cord first the one you have may a resistance problem. Also try plugging it into a different wall outlet. If still the same problem, somehow your convergence circuit has a fault.
