HP PSC 2410 All-In-One InkJet Printer Logo
Posted on Mar 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memoy card error
I have a hp psc 2410 photosmart all in one printer scanner etc.. I have purchased a new sd card and when I insert it into the slot it comes up with "memory card error" please help !
  • Anonymous Jun 10, 2008
     "memory card error" displays on printer when I put camera disk into slot.
  • Anonymous Nov 05, 2008
    I have the same issue
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 25, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
800
Points
Im using XP and have the same problem. I have no Memory card in the slot. How do you clear this error?
Anonymous
Level 3:
Genius:
  • Master 1,665 Answers
  • Posted on Jun 01, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1665
Questions
Helped
978912
Points
3981
angelbear
Level 1:
  • Posted on Jun 08, 2008
angelbear
Contributor
Level 1:
Answers
Questions
0
Helped
800
Points
I had the same problem and it turns out that the memory card slot is not compatible with Vista. If you have Vista Check out the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00810009&lc=en&cc=us&rule=2333&product=303753&dlc=en
HP does not say when this problem should be fixed so who knows how long this will be an issue.
2answers
Hp psc 2410 photosmart driver win7
HP no longer provides support for drivers for this printer. The newer Windows OS will support the printer natively, but sometimes it requires a little finesse from the user. Here is a link to an HP forum where folks tell how they worked out the communications issue for the print and scanning functions. Hope this helps!
adding hp psc 2410 printer to windows 7
Photosmart memory card error
What type and size memory card? The PSC1350 won't work with SDHC cards even though they fit into the slot.
When I insert my 4 gb memory card into my HP printer i get a "memory card error" (My 1 gb card works fine on the same printer).
Well, either the 4GB card contacts are grotty, or the HP PSC 2410 doesn't like your SDHC card somehow; though SDHC cards are supposed to be able to ratchet down to SD for compatibility and a driver update could possibly fix this, it hasn't yet. Use a card that isn't SDHC; this probably limits you to 2GB or 4GB (see the readme in the HP print driver setup package you use.)
Hp 2410xi all in one photosmart printer wont read SDHC memory cards
If you read the manual you will see that the unit will read SD cards, however the high caacity cards (SDHC) are not in the compatibility chart!
HP psc 2410 photosmart all-in-one not piking up paper
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Need a new power cord, how much ?
Here you go:
Compatible Part No:
  • HP 0957-2094
  • HP 0950-4466
Compatible Printers:
  • HP OfficeJet PSC 1350
  • HP OfficeJet PSC 1355
  • HP OfficeJet PSC 2410
  • HP OfficeJet PSC 2410xi
  • HP OfficeJet PSC 2450
  • HP OfficeJet PSC 2510
  • HP OfficeJet PSC 2600
  • HP OfficeJet PSC 2610
  • HP OfficeJet PSC 5510
  • HP OfficeJet PSC 5510 all in one
  • HP OfficeJet PSC 5850
  • HP PhotoSmart 1315 all in one
  • HP PhotoSmart 2510
  • HP PhotoSmart 7960
  • HP PhotoSmart 7960w
  • HP PhotoSmart 7969
  • HP PhotoSmart PSC 2510
  • HP model numbers Q3435AR, Q3435A, Q3501A, Q3087A, Q3090A, Q3094A, Q3020AR, Q3020A, Q3023A, Q3024A, Q3021A, Q3022A
  • HP Bundle PSC1315+M307 Q5776A
  • HP OfficeJet 5500 Series All-in-One Q3434A, Q3435AR, Q3435A, Q3435P, Q3436A, Q3437A, Q3438A, Q3440A
  • HPPSC 1300 Series All-in-One Q3492A, Q3493A, Q3495A, Q3500A, Q3501AR,Q3501A, Q3502A, Q3503A, Q5532A, Q5534A, Q5763A, Q5765A, Q5766A, Q5767A,Q5768A, Q5769A, Q5770A, Q5771A, Q5772A
  • HP PSC 2410 PhotoSmart All-in-One Q3087A, Q3088A, Q3089A
  • HP PSC 2500 Series PhotoSmart All-in-One Q3094AR, Q3094A, Q3095A
  • HP PhotoSmart 7900 Series Printer Q3020AR, Q3020A, Q3021A, Q3022A, Q3023A, Q3024A Q3090A
For HP 0957-2094 PhotoSmart 2410, 2510, 5510 Printers and much more.Come with power cord. Power Rating: 32V 940mA and 16V 625mA
Note: Amps and Watts are maximum load tolerance. Devices only draw as many Amperes or Watts as they needed
For purchasing you might also contact this link below:
http://cgi.ebay.com/Adapter-For-HP-0957-2094-0950-4466-32V-940mA-16V-625mA_W0QQitemZ250414311173QQcmdZViewItemQQimsxZ20090427?IMSfp=TL090427149005r21586
Hope you like my info
3helpful
Hp psc 2410 photosmart all-in-one...cannot make scanner work
I have the same PSC 2410 and contacted HP the print software is included in Leopard 10.5 but the scan is not. They have "no" plans on producing software and went as far as to recommend  third party scanner software to make it work.
Inserting sd photo memory card
If you have to force it, you are inserting it the wrong way. The cards will only fit one way.
k24674
Grand Canyon Tech
Grand Canyon Tech
