do you have the control box cover off? some have a safety switch that will shut the tub down if the cover is removed..find this button and tape it down.. check the rest of the switches for proper operation..either from remote or on the unit..its a process of elimination thing.. I have been doing this for 4 days on our tub.. its finally heating now..only thing is the air blower is not working..
You should probably just send it. They will end up sending you a new one. You poking around in there, you might end up frying the port instead of fixing it. There won't be a diagram because it's a proprietary board. I could figure it out if I had it in front of me, but obviously it's not.
That depends on the game settings. For example if you are playing PES(Pro Evolutions Soccer) you will have use the settings which can be found in programmes files in a sub-folder names Pro Evolution Soccer or Konami (Depends).
What game do you want to play? go to options and in the game settings and choose the controller. You can give me the name of the game so i can try and give specific settings. All the best
all games and most games for that matter do support game pad and so does the pc. Though with some pad you will need its drivers to get it working.
On the other hand games that i call "click and follow" such as rise of nations can never be played with a game pad and also the game must support game pad. For pacman i found out it supports 4 way joystick which means you should not have any problem playing with the game pad since it has the 4 way navigation buttons.
good luck with your game
you must have a small pump call laing if you do, air picket inside the plumbing try to turn both pump on high and wait few minutes if doesn fix try to loose the nut just a little bit with the breakers off and let the air go out. try one more time. if doesn work turn on high both pump and touch if they are working then a impeller may be broken inside one of them try to turn each one separate to find wich one as t he broken impeller.
Hi.
Air flo PC Joystick item 80610 drivers (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
