RCA F32650 32" TV Logo
Posted on Mar 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA TV picture bigger than screen - RCA F32650 32" TV
Anonymous
Level 2:
New Friend:
  • Expert 65 Answers
  • Posted on Mar 05, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
65
Questions
8
Helped
16762
Points
221
If the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Zoom on my TV screen
Hi if the adjustment is not in (ROM) read only memory, it might lose it's memory & reset to normal ::::::::TURN POWER OFF AT THE POWER POINT FOR 5 MINUTES & HOPE IT RESETS.. cheers
I HAVE A HALF SCREEN. BOTTOM HALF LOOKS GOOD TOP HALF HAS WHITE LINES WITH A BIGGER WHITE LINE SEPARATING THE TWO. IS THE PICTURE TUBE GONE OR IS THERE AN ADJUSTMENT I CAN MAKE? TV IS A RCA F25645
This is commonly known as a vertical deflection problem. It cannot be fixed with an adjustment, but requires changing some electronic components. Namely the vertical output IC (integrated circuit) and in addition usually in this model a resistor which may appear to be burned.
I hooked up my computer to the tv and the desktop is bigger than the tv screen can't see the icon or tool bars? res. is set on the max tv menu doesn't have alot of picture settings
Try going into your display properties, and adjusting from there. Right click anywhere on your start screen, and select properties. Then select display properties. Hope this is helpful
2helpful
2answers
The picture is bigger than the screen... Picture is cut off and when I unscrewed the back of the tv I could see that the picture was showing perfect but it was to big for the screen... There's not a way to...
Have you tried hitting the format picture button on your remote control. Seems the picture is in zoom mode. If you have a cable box for HD Channels then look on the remote for a button (format) or Screen size.
Tv problem
Bad capacitors or diodes around the high voltage can cause the picture to bloom "get bigger"
This is not a do it your self repair unless you have componet replacemet expeariance..
1helpful
TV in permanent zoom
The left and right arrows on the RCA remote control are the picture format buttons.....
Picture problems
if it's Narrow on both sides, height and width vary with scenes
try replacing C4407, CR4403
Picture got bigger
Yes, you can adjust the picture by using your remote going to settings, or "Adjust" when your t.v. turns on and off by itself could have'ft to do with nasty weather near you, or the cord is loose and it needs to be pushed in all the way.
2answers
Projects picture bigger than screen..
This must be a duplicate, and since I'm not sure which one you'll be checking back with: Go into the menu and select picture settings and then advanced picture settings. I'm not sure on that model that you can manually change the aspect ratio from zoom to 16:9 or 4:3 ect... But select Auto Format and the TV will pre-select the correct format for viewing..... Any questions just let me know. Bill
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
