Part of the power supply is in protect mode. There is most likely a short or something failed on one or more of the boards.
The service rep would swap out boards to locate the fault. Then he would leave the new board(s) in the set, and perform any necessary adjustments.
Take the set in for an estimate before approving repairs. There are many times these sets are not worth serving when they are out of warranty.
Jerry G.
Hi
There are some factors of this kind of problem.
First you could have a failure in the power supply. Next could be the main board. Lastly you could have a problem with the panel itself, this would mean a new set for sure because the part cost is more than a new set.
However try troubleshooting the problem before spending money on repairing or replacing the television. Possibly you can restore the picture and sound to your television ...
Verify the TV is powered on by pressing the power button on the TV's remote or the front panel of the set. This may seem like an obvious step, but many TVs are equipped with a standby light that will illuminate if the TV is turned off, making it appear that the TV is on when it is not.Cycle through the TV's video inputs to verify that your TV is set to the right one. For instance, if you are attempting to use a digital cable converter box that is plugged into the Video 1 input and the TV is set to a Video 2 input that has nothing plugged into it, the TV will not display any picture or sound and may even say "No signal" on the screen. To cycle through the inputs, use the input selection button, typically labeled "input," "source," "TV/video" or the like.
Re-seat the video and audio input connections to verify a loose cable is not causing the TV's loss of signal. If you have a coaxial cable connected from your wall cable jack directly into the TV, it may have come loose thereby eliminating all picture and sound on the TV. Locate the connection cable or cables of whatever device you are attempting to watch and unplug them from where they plug into the TV. Plug them back in and check for a signal. If there is still no picture or sound at this point, the best option is to contact technical support for further assistance.
