SOURCE: My mom has 32 inch
Hello williskathy2,
This might be a problem with the circuitry of the screen driver. what happens is the one of the drivers in the display matrix IC goes bad and it can not fire that one string of LCD elements, and this creates the line that you see. Since the line is pink, I would say that the driver is incorrectly firing the string of LCD elements. I would suggest that if you have a background in electronics you check the voltage levels on the display driver IC and the connection to the screen. If you do not have a background in electronics I would suggest that you have a qualified TV technician fix your problem.
I hope this helps,
Shuttle83
www.electron-age-technologies-llc.com
SOURCE: thin vertical red & green lines in upper right of 42 in sanyo lcd
More than likely your control board. Available at www.partstore.com Cost could be between $130 and $200. Not that complicated to install if you can use a screwdriver and are careful. Let me know how this works out.
hardrocko
SOURCE: I have a 46 inch sanyo lcd 1080p that is only 2
I'm having the same problem with the same TV. I called around to repair shops and I guess it's fixable. Haven't taken it in yet but I was told it most likely is a bad module. But this seems to be a really common problem with this television
