Press the [Menu], [Start] ,and [up arrow ] button four times quickly in this order to make the machine enter the maintenance mode.
The machine beeps for approx. one second and displays " " on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the buttons.
Press the [8] and [8] keys in this order in the initial stage of the maintenance mode.
(2) The LCD shows the "Reset Laser Unit".
(3) Press the [ ] or [ ] button to select the item you want to reset. The LCD shows.
"Reset-Laser Unit"
"Reset PF-KIT T2"
"Reset PF-KIT T1"
"Reset PF-KIT MP"
"Reset-Fuser Unit"
(4) Press the [OK] or [Start] button, then " *** OK?" will appear on the LCD.
(5) OK: Press the [Start] button to reset the counter of the selected part and returns the
operating procedure (2) mode.
NG: Press the [ ] button to return the operating procedure (2) mode. Then select again
the part which you want to reset by using [ ] button or [ ] button.
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
