I bought a Mackie 1604VZL pro 16-channel mixer on ebay. It is missing some screws on the bottom ''plate'', and a couple of screws on the side plates as well. The mixer is very clean, but it is evident that it has been taken apart or repaired, and all of the screws that secure the bottom and side plates were not replaced when the unit was reassembled. Where can I get replacement screws to fit this unit, or how can I tell what size/type of screws will work? Can I just get something from my local hardware store for this? Also, there are no "rubber feet" on the bottom and I'd like to replace those as well.
A local hardware store with drawers of screws should have what you need. The screws may be metric.
Take a sample screw with and find a nut to fit it to get the size and thread pitch. Then select a screw of that size of an appropriate length..
Nothing is worse than getting something that has obviously been worked on... you know it has a problem that they tried to fix and if you are lucky, they did not create others.
Testimonial: "I very much appreciate this information. I never thought of using a nut to determine the correct screw. This will be an easy fix for me!"
