Quinny Buzz Three Wheel Stroller Logo
Posted on Mar 06, 2010
Can a buzz seat fit speedi frame
Can a quinny buzz seat fit a quinny speedi frame
Anonymous
Level 1:
  • Contributor 15 Answers
  • Posted on Jul 27, 2010
Anonymous
Contributor
Level 1:
Answers
15
Questions
Helped
7042
Points
34
No unfortunately not. The Quinny Dreami carrycot can be fitted as can a maxi cosi car seat using adaptors but not the buzz seat unit.
Quinny buzz 3
Hi
Yes the 2013 style sub seat can be fitted to a 2005 chassis. Where the sub seat connects into the chassis there will be a plastic clip on either side of the 2013 sub seat that will need to be removed in order for the sub seat to then fit into a 2005 chassis.
Does the quinny dreami fit onto the maxi-cosi loola pushchair? If so is the same adaptors that would be used for the maxi-cosi car seat?
Hi
No the Quinny Dreami is not compatible with any Maxi Cosi chassis.
The Quinny Dreami can only be used safely with Quinny Buzz or Quinny Speedi chassis.
For the Maxi Cosi Loola chassis you should use the Maxi Cosi carrycot only.
Will maxicosi car seat adapters fit onto Quinny Zapp as well as Quinny Speedi
Hi
No the adaptors for the Quinny Zapp are different to the ones for the Quinny Speedi.
Can a Maxi-Cosi Mico infant car seat fit on a Quinny Buzz 2006 frame?
The Mico is a USA model only so we are unable to advise from the UK team whether it is compatible with the older style Quinny Buzz.
We recommend you contact Dorel USA on [email protected]
1helpful
Hello - We don't have the Maxi Cosi Mico in the UK, so we're unable to respond to questions relating to this model carseat. Please contact Dorel USA for clarification on this - [email protected]
On the quinny buzz stroller do i need a new frame for the xl seat cover, or will the cover fit the frame of the smaller seat unit?
Good Afternoon
If you have a 2007-2010 model Quinny Buzz you need to remove the infant foam fabric from the sub seat (seat frame) and replace it with the 2nd stage seat fabric (also known as the XL)
For full instructions on how to do this please visit our Facebook page Dorel UK Customer Services and view the Handy Hints & Tips photo album.
Would a bumper bar for a Quinny Buzz fit a 2009 Speedi Legend
The Quinny Buzz bumper bar is only for the Quinny Buzz and will not fit a Quinny Speedi.
3helpful
I have a quinny buzz 2005 frame will a replacement seat unit fit this and will the carry cot fit please
Good Afternoon
The original Quinny Buzz 2005/2006 chassis is not suitable for fitting the current seat fabric. However you can purchase a sub seat (seat frame) which will fit onto your chassis (RRP 75GBP) and the current seat fabric will fit onto that (RRP 40GBP). The Quinny Dreami carrycot is suitable for use on any Quinny Buzz chassis. You can order the sub seat and seat fabric via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
1helpful
Does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
