MY IPOD GOT A MESSAGE ON THE SCREEN THAT THE BATTERY IS LOW PLEASE CONNECT TO THE POWER AND ITS CLASSIC ONE 60 GB I GOT NO PROBLEM FOR 5 YEARS AND I DON KNOW WHATS WRONG WITH IT I THOUGHT IT IS THE BATTERY BUT SOMEONE TOLD ME ITS MOTHERBOARD
To charge the battery, choose one of the options below:
Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge. Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge. Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock. that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Try looking in you itunes folder for a previous version of the software for your ipod if it worked before. The old copies are saved, unless you deleted those folders also. If you deleted them try searching the web for the old software.
Make sure you got the latest itunes version and latest ipod classic version. Also you need to be on the original computer you used to sync with the ipod. Open up itunes and connect the ipod. Your ipod should show up on the computer. Just click on the restore itunes back to factory default button and you should be g to g.
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer. Hold the
Home Button down for 5 second (do not release it) Then
Press and hold the Power Button for approx 10 secs (count them out) Your iPod
will reboot. Release
the power button and continue holding the Home button for an additional 27secs. You may
see the screen go blank or not. Plug the
USB end into the computer with itunes open. Your ipod
will mount in recovery mode. Restore
it and Your all set.
if you need any further help let me know. Good Luck
