Anonymous Posted on Mar 06, 2010
I need to replace the rubber on the paper feed wheel in my Xerox 3117. Is the rubber ring sold separately or as a part of the entire feeder mechanism? What is the relevant part number? Can it be found on the Net? Thanks!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
157
Points
It is sold separately and costs something around 10$..
I don't know the part number but you can get it at your local Xerox service.
You need to press in two plastic buttons from both sides of the plastic roller, and then remove the roller from the shaft. then the rubber goes on this plastic piece with a shape of U (so you don't need to remove the shaft itself). then you clip on that plastic piece and that's it!
Testimonial: "Good advice. Worked for me."
2helpful
3answers
When making photocopies, the automatic top paper feeder is grabbing more than one page at a time. How do we fix it?
Clean all the rollers in the ADF with a damp lint free cloth. Depending on wear, they may need to be changed, but try cleaning first. Where the paper stack rests there will be either a pad or roller, make sure it is clean too.
Will not manually feed paper
Are you talking about the document feeder or the copier. On both counts try to clean the rubber wheels above the feed tray, or up on the document feeder with something like windex or a water cleaner. make sure the wheels are dry, and watch to see if the wheels are turning. If wheels are turning when you feed you need new wheels, sometimes you can rough them up with a grit nail file, or sandpaper.
Xerox phaser 3117 paper jam problem, how to solve it
If paper jams every time, just open printer cover, pull out toner cartridge and you see paper feed roller it is rubber, just clean roller with alcohol and cloth.
I hope this help!
Paper is getting stuck at the begining itself in Xerox printer 3117
Open printer cover, pull out toner cartridge and you see paper feed roller it is rubber, just clean roller with alcohol and cloth.
I hope this help!
Xerox 3117 paper jam
I hope this help!
Lexmark Z52 won't feed paper
You can try to clean it by using a blower maybe there are some debris stuck on the paper feeder assembly. But if its evident that the rubber of the paper feeder is worn out already then probably needs a replacement. but this parts are sold as one assembly it might cost you a lot.
1helpful
2answers
Printer HP PSC 1610XI
Ink Jet Printers are notorious for this. Try using household dish detergent( or any thing that contains glycerin [C3H5(OH)3] ) on the rubber wheels. It appears that the glycerin in the dish soap replaces the glycerin in the material frequently called rubber.
Apply the dish soap to all exposed wheels.
Let soak for five to ten minutes.
Wipe the wheels clean. Clean up any spillage too.
Run a few sheets of paper through the printer (until the damp/oily wheel marks disappear from paper).
Printer should work like new when complete.
3answers
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
ADF won't feed the paper. The feeder wheels are heard turning but the paper won't feed.Replaced the "pad" and cleaned the rollers & glass and checked the feed guide and feed sensor.
If those rollers are turning, and not feeding even after cleaning they simply need replaced. they can get so slick that no ammount of cleaning will help.
Thats what is sounds like.
Like trying to drive a car on ice. No traction.
Pixma i4000 - manual feed picks up 2 to 3 sheets at a time
Get a window cleaning product such as windowlene and a soft but LINT FREE cloth. Remove any paper from the feeder and turn off the machine
Look into to sheet feeder and identify any rubber areas. There should be a rubber pick up wheel and just beyond it a separator pad. There may also be a cork pad in the vicinity.
Use your cloth well dampened and clean all these item as best you can. You can rotate the wheels but ensure you go the correct direction and do not force anything that does not want to move. This will be chore as access is only easy for pixies. Once you have then cleaned and dried off, replace the paper and restore the power.
Try running a print job and see if it makes much difference. If it helps, then you will know that the pick up wheel and separator pad are worn out and could do with replacing.
The paper jam error is related to this issue as the printer is expecting the leading edge of the paper to pass its sensor and then 297mm later the trailing edge should pass the same point. If the machine feeds more than one sheet, the chances are that the paper length will be altered and the machine thinks a bit has been left behind.
Let me know how you get on
k24674
ADMIN Andrew
ADMIN Andrew
