Photo tray problem
' Lift the output
tray up and verify that the photo tray ' is pushed in until it stops, then lower
output all the ' way down. Press OK
button on the printer to 'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper
tray and photo tray
3. Remove output
duplexer (on back of printer)
4. Open input sheet
feeder (on top of printer)
5. Open cartridge
access door. (Basically lift up control panel and scanner section of the
printer)
6. Turn on printer
(Power button on now raised control panel)
7. Printer may
display message "Performing printer alignment - Do not interrupt"
8. Wait for a few
minutes until printer stops making all setup noises.
9. Close cartridge
access door, close input sheet feeder, replace output duplexer, insert paper
trays
10. Do a test print. All should be fine.
