It's possible that the AUX channel was erased from the display menu. Go to your CHANNEL SET menu choice and and use your DOWN CHANNEL button to see if the AUX channel will come back.
Remote,remote and more remote,
go into the menu and select the input i might have been deleted accident ly.
there should be a input button on the remote.
thanks hope this helps please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Well two people told you just about the same thing. And we both got reamed with a not helpful rating how is that for trying to help:(
Sounds like you need a repair shop bud because if its not in the menu the aux port is fried that will cost $50 for the part.. About $45 per hour X 1 hour including talking to you at the sales desk.
total cost out the door
$120 bucks with the tax on my labor on part sounds like a new tv is in order?
$350 from walmart!!
Now I hope this information helped!
I have an old remote and there is no input button on it. I cant get to the aux either. dog chewed my direct tv remote and now all I see is snow.
Wait till The tuner scans and memorizes all the active channels in your area.
ok
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
? When AUTO PRESET CH action is completed, the lowest memorized
channel reappears on the screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH",
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
OK.
on the TV screen.
channels.
OK.
As I noted, I did go the channel menu and ran the preset again.
The last expert told me to try the channel menu to see if running it will bring the aux. back but I already had done that.
