Question about Asko W6021 Front Load Washer
Asko 10505 - wash finished, door won't open
Hi -
i can't open the door to the washer, asko 10505. I ran a load, and it's all done washing, but now the door is clicked shut, and I can't figure out how to release it and get the laundry out. can you help?
Thanks
  • Anonymous Nov 19, 2008
    I have this machine as well and it's very erratic as to whether or not it will drain when the cycle has completed.  I have become quite adept at unplugging the pin trap and draining from there but what a pain in the @#$SS.
    I have cleaned whatever i can, use detergent sparingly but I can't wonder if the fabric soften is the culprit,  i have gone through two motors and other issues with this machine.  Are all the Askos like this?
  • Bates177 Jan 06, 2009
    My front load washer 10505 will not spin and finish the load. Can't open the door. Removed the panel and turned the plastic thing and water is draining, but there is no hose that I can see and I have totally flooded two towels before giving up. Where is the pin trap?
    bates177
  • 49 Answers
It is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
  • Fabswag2012 Sep 16, 2011
    To wiz...iam an asko technician with one year experience...you do know what you are talking about...you should be my tech support...is there anyway I can get a hold of u incase I come accross an unfamiliar problem?my company is located in brooklyn but I service the manhattan area...i appreciate it...
  • Allene Noble Aug 27, 2012
    Thanks so much. I got $.88 from the drain, and all is well!
    New Friend:
The unlock button only releases the door if the machine is turned ON. This is contrary to my washer (a Kenmore). I experienced this on my mom's machine
Posted on Nov 17, 2014
    New Friend:
You have to hold the key lock button down for about 5 seconds and the door will pop open.
Posted on May 12, 2013
  • Houston resident
    Houston resident Nov 17, 2014
    The unlock button only works if the machine is on; this seems counterintuitive.
6ya staff
SOURCE:
I have an asko 10505 washer. how do you open the door?
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Mar 28, 2011 | Asko W6021 Front Load Washer
I can't open the door to the washer, asko 10505. I ran a load, and it's all done washing, but now the door is clicked shut, and I can't figure out how to release it and get the laundry out. can you...
After teh program the latch had to disable but possible that the lock got jammed or the end link is not connecting.
Look from the bottom and you can access the lock section to release and get the lock function.
Once it opens use good degreasing spray and then oil then lock as there can be rust or dirt that has got it stuck.
The end program safety link must also work.
Sep 02, 2010 | Asko W6021 Front Load Washer
Unable to locate any info on a model 10505 se # 982410041588
Hi, I may be mistaken but I don't think so, that number ( 10505 ) is for an Asko washer built in 1998, not a dishwasher. Do you require assistance with your washer ? I will watch for your reply. Macmarkus :)
Mar 17, 2010 | Asko Dishwashers
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
Leaking inlet valve on Asko 10505
Unfortunately, the only way to be 100% sure this won't happen again is to replace the inlet water valve. Especially if the problem is intermittent. You could live with it if you turn off your water taps when the machine is not in use.
Feb 19, 2009 | Asko W6021 Front Load Washer
Can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Oct 16, 2008 | Asko W6021 Front Load Washer
Repair front load washer
wash machine not draining properly at end of wash. not fully spinning.
pls advise
Sep 11, 2008 | Washing Machines
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Using asko washer front load
Close the door firmly.  It won't start until the door is sealed shut.
Dec 10, 2007 | Asko W6441 Front Load Washer
Asko W6021 Front Load Washer Logo
6,917 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
ROB
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
