Ebay seems as good as any ....
http://cgi.ebay.com/ADS-18H-12-AC-Adapter-9v-2A_W0QQitemZ250532141467QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a54e1199b
Satisfy yourself its the right thing before purchasing (The SKU matches, but that doesn't necessarily mean.....)
Hope this helps
Thank you for your post, Jeff Duvall!
I see that your Frigidaire washer is displaying an error code of "18h". However, it appears "18h" is an invalid error code. In order to clear any false error codes, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for approximately ten minutes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "18h". I look forward to assisting you. -Matt
Hey friend, thank you for the post!
I see you are getting an 18h code on your front load washer. Normally any error code would have the letter E or F in it. I would suggest that stands for 18 hour delay start cycle, you could do a reset on your washer by disconnecting power to it or turning off the household circuit breaker for ten minutes and turning it back on. Hope this information is helpful. -Matt
