Trouble indicator came on after a power outage and
Multiguard Burglar Alarm 12 years old - trouble indicator came on after a power outage and remains on even though power has been restored. Pushing the reset button does nothing. Burglar alarm still works but occasionally the thing will beep intermittently until one fiddles with it, then it quits but the trouble light remains on.
Re: trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Filter Replacement Filter Replacement Indicator: Your Defender® is equipped with a Filter Replacement Indicator located on the front panel. Anytime this red indicator flashes, it is recommended that you call your authorized FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops flashing and remains solidly illuminated, it is recommended that you change your filter. To receive full benefit from your Defender® and to extend your warranty, it is strongly recommended that you follow the filter replacement schedule suggested above. Under higher pollution levels, your filters will need to be replaced more frequently. The Filter Replacement Indicator is operated by filter time in use and is controlled by an onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter Replacement Indicator will begin to flash. It will continue to flash until the you reach 12 months of time in use, at which time the Filter Replacement Indicator will stop flashing and remain solidly illuminated. After replacement of your Medi-Filter® Cartridge, you must reset the Filter Replacement Indicator's timer. When the timer has been properly reset, the Filter Replacement Indicator will turn off. Resetting the Filter Replacement Indicator Timer: After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the Filter Replacement Indicator's timer can be reset by performing the following sequence of steps: 1Plug unit into outlet. 2Press power On/Off switch to the On ("I") position. 3Allow unit to start running at low speed. 4PRESS and HOLD both the Up and Down arrow buttons until the Filter Replacement Indicator starts to blink. 5 Release both the Up and Down arrow buttons. 6 While the Filter Replacement Indicator is still flashing*, again PRESS and HOLD both the Up and Down arrow buttons until the Filter Replacement Indicator turns off. If the steps above have been performed properly, the Filter Replacement Indicator will turn off and not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again. *Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time. The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above. Note: Under higher pollution levels, your filters will need to be replaced more frequently. Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call 1-440-846-7800 for the Distributor nearest you.
Mine was the power supply. I was able to repair it though. Pleasd contact me before you throw it away. I need a touch screen. My daughter used it for a drum!! [email protected]
1. Plug unit into outlet.
2. Press power ON/OFF switch to the ON position.
3. Allow unit to start running at low speed.
4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink.
5. Release both the UP and DOWN arrow buttons.
6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commission is going to be making a decision on ionizers at the end of year since there are hazards in the air from using the devices. It could be that ionizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it.
Reset filter reminder:
Unplug power code.
Push and hold sleep button.
Plug power code while pushing sleep button.
LCD shows "P" than release the button.
Push sleep button and you can see 99% filter reminder.
We purchased one of these in April 2009. Same issue appeared with us. Cleaned the cell and the "clean collector cell" still stayed illuminated. Checked the manual and the trouble shooting section stated to hold down the "air revitalizer button" till the "clean collector cell" light blinks three times. After this operation the light went out and all was fine!!!! Hopes this clears your issue!
