what can i do if stuck with recovery mode ? i had done reboot ,
format , clean up and reload firmware but it doesnt worked at all . does
it cannot be fix anymore ?
You must have a software glitch because the flash is supposed to be in the auto mode when the selector is in auto, unless you manually turn the flash off and the flash should go back to auto every time the camera is turned off and back on. Here's a work around. Turn the dial to indoor and use the flash button on the ring to set the flash to auto. In the indoor setting you can set the flash to on, off, or auto.
This sound like you have the system in Valet mode. You must locate the valet button usualy located inder the drivers dash or kick pannel. just turn key to on possition and hit button and then take key out. that should do it.
