Not sure what email program or service you are using it could be the size of your files are too large. If they are pictures you can resize them smaller in pc paint and then save the smaller size and try sending the smaller file. If it is a document with inserted pictures you may need to resize the inserted pictures and try sending the downsized document file. If you are trying to send a large file like a video file you could use a drop box service but remember files should not be used if confidential or intellectual property sensitive to you.
https://www.dropbox.com/business?home=true&_tk=sem_b_goog&_camp=sem-b-goog-au-nz-eng-top-exact&_kw=drop%20box'e&_ad=44814131022'1t1'c&gclid=CjwKEAiA9uaxBRDYr4_hrtC3tW8SJAD6UU8GQ0kapAA-WjXr8JmmyiaPlGFp_YPERH3-40p25dJH3BoCorjw_wcB
I've with me the manual of Vizio E470VA user manual. But I can,t send it to you through this site, because it allows me only upto 50kb to upload. The document I have 1.43Mb capacity and contains 62 pages as anAdobe Acrobat-10 document. If you send me your email address to me, I'll send it to you as an email attachement. If you can download it by yoursef, inform me. I'll guide you. OK.
You send them as attachments to your email. Just pick "attachments" and you will find a dialog box where you can pick the documents you want to send. You can send 5 or 6 at a time, just keep picking the documents. Hope this helps.
you can do that by following steps
1.scanning all that pages and save them as different files in your computer.
2. open a word document and copy all the contents of the five different files and paste them in the word doc and save it
3. while mailing you can attach this word document to send all the files as a single attachment
When scanning a document it is common for the scanner to use a high resolution and color mode both of which increase the size of each scan. There is a limit on the size of an attachment which varies with your e-mail and or Internet provider. It is best to keep attachments as small as possible. You can change this in the settings menu going to black and white and setting the DPI (dots per inch) down from 300-600 to 150 or even 75 and the scan will be fine but a smaller file size. If you are sending color pictures you can make them smaller but the quality will suffer some and you will still need more then one e-mail but with adjustment of the settings you can reduce it to a minimum. I hope this is useful to you. Good Luck
The simplest and fastest option is to compress the document with either WinZip or PKZip. That compression makes the software ignore the attachment. Both programs are pretty universal so that recipients would be able to uncompress the files at the other end. You can download the programs for free from www.tucows.com. Just search their site for those compression applications. If you are on a Mac, you can obtain Stuffit to do the same thing.
Single scan printers can be difficult in this manner.\
Consider using the OCR (optical character recognition) software that came with your scanner.
Basically the part of the software that asks you what you are scanning (picture, document, newspaper) and make sure to select document. This will enable the character recognition which will convert the scanned picture into a document that you can configure to go into Microsoft Word or Notepad or whatever. If you have multiple pages, it MIGHT give you the option to scan more than one page at a sitting. then again, it may not. In which case you might be kicking yourself for not purchasing the scanner with the auto feed attachment! Once you have made your scanned document in your word processor - READ THROUGH IT! may have converted characters incorrectly - like an "S" may be now a "$" it happens - and it will happen. When done, attach complete document to email and BOOM done.
