Question about Maytag Atlantis MAV6451 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
I have a Maytag Atlantis MAV6200AWW. The washer cycles, but stops at extra rinse...fills up and shuts down with the tub full of water. At the rinse setting it partially drains and refills. The cold water will not work and only blazing hot water will come out. Motor and pump work great. need help
    Habit-Forming:
    New Friend:
  • 121 Answers
Hi
the solenoid on the cold water is gone down or it is not fed with electric
Posted on Jan 30, 2018
6ya staff
SOURCE:
Anonymous
  • 45 Answers
SOURCE: Maytag Atlantis Washer - MAV6200AWW
bolt has 1/2inch head but dont know the thread size is an orderable part 3 to 5 dollors, may not agitate since agitator not on shft to turn
Posted on May 16, 2008
Anonymous
  • 261 Answers
SOURCE: maytag mav6200aww removing inner tub
I broke a hammer removing the basket on a 6000 series today. These are known to be a real ***** to remove. Once those screws are out there is a seal nut to remove and the basket hub assembly is what it sits on. Look at 5 and 7 below.
Posted on Oct 12, 2008
Anonymous
  • 20 Answers
SOURCE: Maytag Atlantis MAV6200AWW Washer Problem?
is your drain hose at the top of the washer .is the water just runing out is it being pump out
Posted on Feb 20, 2009
Anonymous
SOURCE: Maytag Atlantis MAV6200AWW; Washer goes through
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
Posted on Jun 12, 2009
Anonymous
  • 16 Answers
SOURCE: my maytag atlantis mav6200aww stops at the rinse
Sounds like a bad timer, which is built into the switch. Replace the timer.
Posted on Jul 02, 2009
My maytag mav6200aww washer stops at the rinse or the spin cycle. However, if I wait about 30 min it will work. Possibly a bad timer? Are they difficult to replace?
If the washer is working properly in the wash cycle & not the rinse or spin cycle, I would suspect a defective timer especially with the delay of 30 mins you described. Replace the timer with this part.
Jan 14, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Water not filling in tub washer spins,
It sounds as if the timer has failed internally. Spinning on each setting means the motor is not reversing and that reverse function is controlled by the timer itself. It would never fill if it is stuck in spin unless you select rinse and depending on cycle it can inject water in the spin during the final rinse. If your machine does this normally see if it injects water. If it does inject water at that point I am 95 % sure your timer is the problem.
Jan 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold water
ck for cold water coming in ..washer probably set to run cold only rinse on color cycle
Aug 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
162 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
