Hello, I beleive I can help you but first I would need to know what year/make/model of vehicle it is installed in. Thank you.Hello, I beleive I can help you but first I would need to know what year/make/model of vehicle it is installed in. Thank you.
You can't post conmments that contain an email address.
Sounds like it is running out of fuel. Maybe a bad fuel pump, or clogged filter. If it is carbureted, a stuck float valve or clogged float valve might be the problem.
Telling us year, make and model would allow us to help you more.
your not getting fuel threw the carb see if it is getting to the carb by removing the hose next check for power to the solenoid on the bottom of the carb a bad safety switch will shut it off they aslo stick from having bad fuel remove it clean it and check it for movement with power and ground
if you have the manual at hand, put key in ignition and turn to the on and off position fast as you can and then push button. it should not rrespond because thats resets the alarm, follow manual on how to reprogram! hopes it helps out. I have bulldogs rs 1200 and trying to unlock my doors via keypad. locking them with no problem
PRESS AND HOLD THE BRAKE PEDEL, PRESS AND HOLD BUTTON 2 UNTIL PARKING LIGHTS FLASH 2 TIMES, RELEASE BUTTON 2 AND PRESS AND HOLD AGAIN UNTIL 2 FAST FLASHES ARE HEARD, RELEASE BRAKES AND LIGHTS WILL FLASH 3 TIMES, THERE ARE 7 DIFFERENT SETTINGS SO IT MIGHT A COUPLE SECONDS TO COMPLETE
there should be a way in the settings of the brain that lets you pick a longer cranking time. idk exactly how to do it but if you look in the manual that came with it or go on the web site or call the company they should be able to help you
I've wired several of these and you have likely hooked up the wires wrong its not giving power to the right wires at the bottom of your steering column...........re check your connections on your truck there are 3 wires that need power for the starter to work they are the orange,pink and brown hope this helps!
