JVC AV-48WP30 48" Rear Projection Television Logo
Posted on Mar 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA HD52W59 CONVERGANCE WONT SET
CONVERGANCE WONT SET, IT STARTED TO THEN STOPPED AND THE OPTION IN SETUP WENT AWAY NOW MY COLORS ARE 2"-3" OFF. I ADJUSTED TUBES SLIGHTLY NOW ICAN SEE IT BUT ITS HALOED, ANY ADVISE.
Sonny Berry
Level 3:
  • JVC Master 8,617 Answers
  • Posted on Mar 11, 2010
Sonny Berry
JVC Master
Level 3:
Answers
8617
Questions
Helped
1721889
Points
23750
You need to install the RCA repair kit called the ITC222A convergence option missing repair kit from www.tvrepairworld.com the kit has the Cd with instructions.
RCA 52 HDTV Projection color is going in 3 different ways like I'm looking in an hour glass!! Does anyone have an answer???
very easy repair on that model depending on wether the auto convergence option is still listed under the setup menu options. Let me know if its still listed and I will assist you with the issue.
1helpful
I have an RCA hd52w59. I just got it today used and I don't have a remote for it. The colors wont converge and I think it is a Convergence Chip Failure from what I have read on here. But one of the ways...
chek to see is the setup menu has the word convergence on page.
if not the the problem is an open 0.4 fuse beside the flyback/center one of three in a row.
the fuse blows because the flyback need to be resolderd, cracks on pins.
4helpful
3answers
My rca hd52w59 tv looks like its in 3-d. auto covegnence used to solve the problem most of the time but now it does nothing. pic is constantly looks like 3-d now. the colors r all not right. i get it close...
Hi
Thanks for using FixYa. You’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. You can buy the convergence chips from this link; also if you want you can buy repair kit which comes with complete installation and parts. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
5helpful
5answers
Pic has a big bow in it and the colors don,tline up, went and had a new convergence board installed and still have the same problem
Is the convergence option still listed under the on screen menu's setting options or has it disappeared? Let me know and will assist you with the problem.
My auto convergence has disappeared, and my colors are messed up
The ITC222 and ITC222A convergence option missing repair kit fixes tha issue. The kit is available at www.tvrepairworld.com and has complete instructions on CD
The auto convergence setting is not in the setup menu
the ITC222 convergence option missing repair kit under RCA repair kits will fix that issue. The kit contains the parts and detailed instructions. heres where to get the kit.
http://www.tvrepairworld.com/
R52WH74 WONT CONVERGE
first question is the picture also bowed in on top and bottom. if so you may have the common fl231 fuse problem if you do consult the fl231 problem under the tips and tricks section. if you dont then you defently hav a convergence issue. the thing to look for is under setup do you have the autoconvegence option if you dont then you have that problem.
HD52W59 HDTV
Sounds like the fl231. First question? In the setup menu do you have convergence option? if not this is an indication of the special fuse called fl231
6helpful
2answers
RCA HD52W59 Projection Big Screen TV
This problem is commonly refered to as a CONVERGENCE problem. Question 1 do you have convergence seting in setup menu...if you do NOT it could be a special small fuse. 2 if you go into setup then convergence. then can you move crosshairs in setup. Since you have a arcing picture this indicates convergence power supply problems....in which has to be replaced or repaired,
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
