Question about HP PSC 2355 All-In-One InkJet Printer
My HP PSC 2355 is not supporting SD media cards. It put the card in the appropriate slot on the printer, then the "camera" LED flashes red. On my computer, the card shows up, but I either get a "insert media into drive ..." or "... cannot be read due to an incorrect function"
  • Anonymous Mar 10, 2010
    The printer says "Memory Card error."
    I'm starting to think it may be time for a new printer, considering it has a half-full color cartridge in it and it is behaving like it does not have one.
  • 232 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00249500&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Hope that will help!
Posted on Mar 09, 2010
6ya staff
SOURCE:
The 2355 gives an error when I plug in a SD/SDHC Memory card, it won't read it.
Your HP all-in-one can read the following memory cards: CompactFlash (I, II), Memory Sticks, MultiMediaCard (MMC), Secure Digital, SmartMedia, and xD-Picture Card. Note: It will not read an SDHC.
Jan 21, 2011 | HP PSC 2355 All-In-One InkJet Printer
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
I have a HP PSC 1610 All in one printer and I tried putting my media card in the SD slot and it tries to read the card but the red light flashes and says memory card error. HELP Please!
If using the Card Reader -
The HP all-in-one has detected an error with the memory card.
1. More than one memory card is inserted in the HP all-in-one.
2. An incompatible camera is connected through the camera port.
3. A memory card is inserted and a digital camera is connected at the same time.
Solution:
Remove and reinsert the memory card. It may be inserted incorrectly. If the problem continues, the memory card may be defective.
Remove one of the memory cards. Only one memory card can be used at a time.
Check the user guide that came with the camera to see if it supports PictBridge. If it does not, try using the cable that came with the camera to connect the camera to the USB port on the back of the HP all-in-one instead of to the HP all-in-one camera port. If the camera does support PictBridge, make sure the camera is set to PictBridge mode. See the user guide that came with the camera for instructions on how to do this.
Remove the memory card or disconnect the camera. Only one can be used at a time.
You might try the following - Reformat the memory card in the camera or format the memory card in a Windows XP computer by selecting the FAT format.
Hope this helps!
May 01, 2010 | HP PSC 1610 All-In-One InkJet Printer
Cannot send pics from memory card to computer
http://welcome.hp.com/country/us/en/support.html
This is the HP support website,they have some excellent walk thru's to self diagnose printer problems.
Dec 20, 2009 | HP PSC 2355 All-In-One InkJet Printer
Sd slot used to read cards, now "memory card error"
i am trying to copy my photos from my 4 GB SD memory card on to my computer through my printer HP PSC 2355 all in one printer. But as soon as i put the card into the slot it turns green and the a couple of minutes later turn Red and flashes and i cannot read it on my computer
Dec 04, 2009 | HP Office Equipment & Supplies
Card reader not working?!
Have you tried another memory card?
Some devices can read SD but not SDHC. If your memory card is 1 or 2 gig, it's SD, if it's larger, it's SDHC which is not backwards compatible with SD.
Based on the age of the PSC 1350, I would bet it's a SD-only device.
Nov 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
Error:0xb9000027
with my pc hooked up to the printer i get error
codes on it it is a psc 2355v all in one
May 12, 2009 | HP PSC 2355 All-In-One InkJet Printer
Trying to import pics from Canon SD1100 via HP PSC 2175 printer
Do you have access to another card to try in the printer to see if it works, this would help isolate whether it is actually your card or the reader?
Can you connect your camera directly to your PC via a usb cable to upload directly to your PC? Or do you have a card reader on your PC that you can try the card in? If not, you can buy a USB to SD adapter for about $15, so you may try that.
It could be that the card somehow became damaged, and may be unusable.
Those are a few options you can try anyway.
good Luck ;)
Mar 17, 2009 | HP PSC 2175 All-In-One InkJet Printer
Photo memory cards
Check the types of card supported in this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00649&cc=us&lc=en&dlc=en&product=79499 as the card you have is of a new technology is is not met for the old All-In-One printers, in the old Printers they do not take cards of higher memory cards
Aug 23, 2008 | HP PSC 2210 All-In-One InkJet Printer
Problem getting HP Photosmart to recognize digital camera memory card
From what read of the specs, the C6100 does not support SDHC cards, only SD cards. SD cards top out at 2GB; what you have is technically an SDHC (High Capacity) card, which does not work in SD devices.
Jul 22, 2008 | HP Photosmart C6100 All-In-One Printer
HP PSC 2355 All-In-One InkJet Printer Logo
210 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
