I fund this by dargan and it worked for me "Def" Camino Real 3, Panama: Region code hack posted by dargan, August 23 2008: Same hack for DVD283 worked for DVD-277
<clipped from other post> Region code hack posted by mhardial, January 25 2008: DVD Regional Codes Code Location **1** USA (incl. territories), Canada 2 Europe (Germany), Japan, South Africa 3 Southeast Asia 4 Latin America, Australia, New Zealand 5 Russia, rest of Asia and Africa 6 China 0, 255, 9 MULTI REGION
Region Code Change
NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
DVD Players
New DVD283 1. Open DVD Tray 2. Press the “Menu” button 3. Press 8888 4. Press the “Display” button 5. Region Code Number shows up. Use the numeric keypad to select your region code number (0 – 6). 6. Press the “Setup” button to exit.
1. Press Power ON [ without any disc in the tray]
2. Press "Pause".
3. Enter digits [1-4-1-5-9]
4. Enter the desired Region Code.
5. Press "Pause".
6. Turn the player "OFF" and wait for a few seconds.
If it is not working, you can try to remove the region code from your DVD. Leawo DVD Copy is designed to copy DVD to ISO image file, blank disc or folder. As the most powerful DVD copier, it can also remove the region code from your DVD after copying. You can use it to back up your DVD disc to either your hard drive or a blank disc or directly copy ISO image file to a blank DVD disc.
You may need to look through the manual book of your dvd player and maybe you will find the answer you need sometimes you might have to call the 800 number on the back of the manual book so they can better assist you.
Press the Pause button on your remote control. Using your remote control enter the code 3, 1, 4, 1, 5 and 9, Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player Or Press the Setup button on your remote control then, Step, Next, Up and Down, select the region of your choice or Bypass for region free, save and then Exit the menu.
LG 3200E, LG 3520, LG 4351, LG 4721P, LG 4730, LG 4821P, LG 4950S, LG 5083, LG 5822N, LG 593W
HI, paste link below into your browser and follow the instructions. The unlock code for the 6053 is the same as for the 5931. Simply burn the disc and put it in your player. I used this site to unlock mine, very worthwhile.
YES, it can be changed to view all regions. I've just done my new RC388 (bought it 4 hours ago) and it works.
To start the hack: Click the home button on the remote, go to the Setup page, highlight the 16X9 TV aspect ratio and enter in this coded sequence: 1 3 9 7 1 3 9
A new factory menu now comes up on the screen.
To change the values of these options hit the enter button and scroll with arrow keys until you get to the option you want to change. For the region code hack replace the value of "option 5" with the value of: ff
Press enter.
(Changing this value will set unit to region code 0 which should allow any region to be played on the player.)
Now, hit the "return" button to save and exit.
Switch off the machine - switch on - all is well now.
To make this player region free (or change the region), do the following:
* Ensure that there is no disc in the player (ie: "no disc" is displayed).
* Press PAUSE
* Enter 314159
* Enter the region code (0 for region free, or 1-6).
* Press PAUSE
* Turn the player off for a few seconds.
* Turn the player back on
* Voila! You beauty!!
Turn on the unit, with remote, (no disc in player), press pause, then key 3 1 4 1 5 9 Instructions for changing region code appear on screen, Set to Region or Disc you want to play, 1, 2, 3, 4, 5, 6, or 0 for all. Press pause again. Turn off machine.
dvd/vcr combo flashes "locked" on display
