Question about Skull Candy Skullcrushers Headset
Bass speaker buzzing
My bass speaker is buzzing when bass hits very annoying what do ido
    New Friend:
I've had this problem too multiple times. Usually when it happens, the battery dies soon after, and once I replace the battery, the buzzing goes away. If you are having the same problem as me, try putting a fresh battery in :)
Posted on Jul 04, 2010
  • 2 more comments
  • payneliketos Jan 12, 2011
    thanks man it worked. mine had the same problem now its all good.
  • Telmo Tempor?o
    Telmo Tempor?o Nov 14, 2013
    OMG thanks bro, i was so scared!
  • pramod kumar Jul 23, 2014
    dont buy this product
    Add a Commenti sent my product to the customercare due to the bass buzzing but not yet got a good result .so please dont buy it
    New Friend:
Yeah. Just add a fresh new battery and it goes away.
Posted on Nov 18, 2011
  • 119 Answers
Sounds like you blew them up....not made for music that needs a 12" subwoofer
Posted on Mar 09, 2010
6ya staff
SOURCE:
Annoying sound
Hi Anita
Determine source of Buzz
Speaker --- Computers sound channel Amplifier
Left or Right channel
Can you hear buzz in earphones
Fan --- Speed changes with Temperature - insects or junk hitting on fan
CD --- Player mechanism - CD media left inside
Good Luck
Dec 06, 2013 | Toshiba Satellite Computers & Internet
Buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
G..
Nov 03, 2011 | Logitech Z-4 Computer Speakers
Sub-woofer driver rattle/buzz.
Bad news! It sounds like the coil is rubbing inside the magnet of the speaker! There's no cure, when the cone is warped it it knackers it up. Had the same problem some years ago with a Wharfedale speaker. Someone told me you can hit it on the part where the cone joins the magnet -with a hammer!
Anyway it didn't make a bit of difference! And the speaker was chucked.
Feb 09, 2010 | Polk Audio PSW150 Speaker
Logitech Z-2300 subwoofer/Bass volume cannot completely shutoff
Make sure the wired remote is connected completely and if that doesn't work try putting a pillow or a pile of blankets to cover both the subwoofer driver and the air port on it and that should reduce the sound coming from it. Also if it is in a corner or on a solid floor like wood or tile i would move it to a less enclosed space with carpet or a rug. Thats all I got I hope that helps.
Feb 05, 2010 | Logitech Z-2300 Computer Speakers
Annoying buzz on my speakers !!!
sounds like a ground issue. perhaps invest in an isolating 4 way 13 amp power cable as this will suppress any noise potentially being caused by other devices (such as lights) that may be on the same circuit as your audio hardware. failing that it could be that there is some damage to the cable you are using to connect your speakers to your computer. if they cannot be replaced you will need to have the connections serviced.
May 01, 2009 | Electronics - Others
Keep blowing out bass on speakers Denon 75rd
Thank you for responding. I called in an audio specialist to look at the whole system--he believes there is a problem with the amplifier. Will post what he finds out when he looks inside.
May 01, 2009 | Denon DRA-375RD Receiver
Sound vibrates
Test it by moving the bass and treble up and down. If the buzzing seems disappear at lower volumes with little bass and appears from one side only, it is probably a blown speaker on that side.
If the buzzing is apparent even at very low volumes or from both sides, it is probably an audio board issue. I am not certain if your model has a separate audio board or that functionality resides on the main board.
Dec 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Sharp Aquos rattling bass
the sharp some models dont put a spacer between the speaker and the case causing the speaker to hit the case at med to high volume you can check this and make you a spacer out of washers on each screw that mounts the speakers between the case and peaker frame make sure that the washers or spacers you use dont contact the speaker core. and dont do anything that will void the warrenty if nothing else let the store fix it.
Dec 12, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Skull Candy Skullcrushers Headset Logo
2,109 people viewed this question
Top Skull Candy Radio Communications Experts
Anthony Ward
Anthony Ward
Marvin
Marvin
Are you a Skull Candy Radio Communication Expert? Answer questions, earn points and help others
