If your OS is Win7 64 bit, then incompatibility must be occur because Windows XP use 32bit Operating System and driver software usually only special for each OS (x32 or x64). About upgrading the software, how will you upgrade while you can't even install the basic software in your PC ? The choice you have is find another driver that compatible with your OS, you can search via Google, and I hope you are lucky enough to get it available or even free to download. If you still want to upgrade, then the Windows7 is the one to be upgraded so you can use XP Mode system. You must have Windows 7 Professional, Enterprise, or Ultimate to run Windows XP Mode. You can visit microsoft.com for details.
I believe that windows 7 has a nice thing called Troubleshoot Compatibility. If you can find the executable or shortcut to it, you can right click and Troubleshoot it. Windows should automatically find XP as the best to run the program. Also, if its just a warning you should just bypass it. I can't see any reason why it would work on XP but not 7.
Remove the camera software entirely.
Assuming you PC is 2000/XP no camera software or driver is required.
It should simply come up as a new drive in My Computer
Come back on this one
If the removable disk does not appear when you open "My Computer" in Windows, it is possible that the USB drivers are not installed correctly.
Update to the latest version of FinePix Viewer (including the USB drivers). To update FinePix Viewer, you must have the software from the CD-ROM bundled with the product (Utilities for FinePix) already installed.
As an alternative method to updating the software, you can also reinstall the USB drivers. The USB drivers can be reinstalled by installing the software from the CD-ROM again.
If the removable disk is still not displayed after the above measures have been taken, check the following:
Windows system checks
1. You should be using Windows 98, Windows 98SE, Windows ME, Windows 2000 or Windows XP.
2. The Windows XP USB drivers are supported as standard system drivers but are only compatible with Software for FinePix versions 2.0 or later. If you are using an earlier version of the CD-ROM, an update to FinePix Viewer is required.
3. The software cannot be installed properly from "Scanners and Cameras" in the Control Panel.
Digital camera checks
1. Check that the digital camera can play back images on its LCD monitor.
2. On digital cameras with the PC Camera function, select "DSC" as the USB setting. (Refer to the Owner's Manual for your camera for information on specifying the camera settings.)
