KDS K717s 17" LCD Monitor Logo
Posted on Mar 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My monitor is fine, I cannot find the power jack. Do you know where I can find one?
wisiny.com
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • KDS Master 848 Answers
  • Posted on Jan 03, 2015
wisiny.com
KDS Master
Level 3:
Renaissance:
Answers
848
Questions
0
Helped
454056
Points
4753
My monitor is fine, I cannot find the power jack. Do you know where I can find one? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 170DTLAPH PI 170DTLA 200 000 170DTLA AH 860 AB0 170DTLAPH Power...
Anonymous
Level 3:
  • Master 561 Answers
  • Posted on Mar 09, 2010
Anonymous
Master
Level 3:
Answers
561
Questions
0
Helped
179248
Points
1723
Hi
Please see the following link
many available for fairly cheap prices
http://shop.ebay.com/sis.html?_kw=KDS+LCD+Monitor+17inch+17%22+k717+k+/+717+700p+/+700+p&_nkw=KDS+LCD+Monitor+17inch+17+k717+k+717+700p+700+p
I hope this has been useful
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    We set up the monitors in our pmp 6000 at the mon send jacks but we didn't get any sound from it when we turned up the monitor volumes. What is the proper way to set them up?
    I HOPE you know that the monitor send jacks are NOT powered. You MUST use either powered monitors or an external amp for these to drive speakers. Assuming you have done that, you have to turn up one or both of the monitor knobs for each channel you wish to send to the monitors at the desired level. Then you advance the monitor faders for the overall monitor level.
    Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
    Thank you for using FixYa
    I would try shutting down the computer in the normal way, and turning off the monitor.
    Boot up and turn the monitor back on.
    If it still doesn't work, then I would check the cables and power plugs and wall plugs.
    Check the mouse and keyboard cable and any other cables plugged into the computer.
    The next step requires a seperate monitor or laptop.
    Try unplugging the monitor and pluging in another monitor. Most laptops have a common
    VGA adaptor jack or even an Svideo jack.
    If the other monitor does not work, Then take to a qualified technician for repair.
    It could be your power supply in the computer or video controller.
    I hope this was useful and please comment if this was helpful to you.
    I dont have a power cable.where do i find?
    A) If it is a standard kettle lead (see image linked below) then you can get these cheaply pretty much anywhere, cash converters always has these for around £2 or so
    http://www.whitedog.co.uk/catalog/images/ukmains_lead.jpg
    B) If it is a DC jack power supply then you'll need to match up the right jack, the right volts, and the right amps. IF this is the case then let me know all the details on the label (input volts and amps) and I'll find you a suitable replacement, I may need a pic of the dc jack though,
    C) you could advise the exact model number of the monitor and I can find out all of the above myself and let you know
    DGM monitor - jack no longer fits
    I don't know what model monitor you have. If you say that jack does not fit the socket. Check the pins in the jack, if some are bent, try straighten them out with a pair of pliers and see if that fixes the problem.
    3answers
    How do I get sound from the Acer LCD monitor?
    connect stereo audio cable from monitor to pc audio output
    Power on/off
    Hi, Try using another outlet.
    Does your AC power cord have any indicator lights which is why you know the power cable works fine?
    Base on your assessment, I would say the power supply board on the monitor needs to be replaced.
    Thanks,
    Mike H.
    Top KDS Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ADMIN Eric
    ADMIN Eric
    Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
