www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
? 1:53 www.youtube.com/watch?v=zrV9w6Z5LAU Mar 3, 2012 - Uploaded by briantaylor62
Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
? 1:23 www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
Try pushing high temp wash>heated dry>High temp wash>Heated dry that should reset the control but it will most likely come back count the number of flashes before a pause.it's an error code could be a heating cycle failure.
If the control doesn't reset you have a control or touch pad issue.
Aureley, We would like to inquire further about your post with you. Please respond back to this email address [email protected] with your name, user id (Aureley), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Hi Curtis: File a class-action suit against the Whirlpool company. There is something wrong with the electronic module that tells the washer to shut down during the rinse cycle.
If you pause, lift the lid, pour in about 3 gallons of water into the tub, close the lid, push start, the washer should continue without having to wear out your fingers pushing the buttons. The buttons will eventually be pushed down into the control panel and you will have to use a pencil to reach them.
Also helps to have a nice cool bottle of regular beer (not the light stuff) before you start the load, the washing duty will work out much smoother. Good Luck.
Your Central Control Unit is most likely the problem. It is the main board in the machine behind the control panel and they have been failing a lot. This is a major problem with the Whirlpool Cabrio and the Kenmore Oasis machines. You will most likely need to call a service technician. People have also called whirlpool and complained and got them to pay for the part. I suggest you try battling with them. The part is faulty.
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
