Question about Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens
Nikkor 18-200 mm VR with loose front ring and stuck zoom barrel
After less than one year of ownership the front ring of my Nikkor 18-200 mm VR lens started to come loose. It gradually came more and more loose until it was only hanging on by one screw. The zoom barrel also started to get stuck in the 18 mm position. In order to zoom in I have to help it out of the 18 mm position by pulling the barrel slightly. Sometimes it will not focus in the 18 mm position. Sometimes it will. The repair center which Nikon Denmark uses claims that the lens has been dropped and the repair cost would amount to USD 855, almost the same as a new lens. I don't recall dropping the lens at any time. Now I am stuck useless lens and will have to pay the repair center USD 130 for the investigation and returning the lens.
Is this a common weakness of this lens or is it just bad luck? Should I be able to claim this repair under the Nikon warranty?
    Brigadier General:
  • 3,006 Answers
Unfortunately not. If the Nikon centre think it's been dropped, then you're stuck. They may well think so due to additional wear and damage caused as the initial fault progressed; this may well resemble the damage caused when a lens is dropped. You should really have sent it for repair as soon as the fault occurred.
All you can do is to write a letter of complaint to Nikon, asking them to intervene on your behalf with their authorised repair centre. It will help if you tell them how long you've been loyal to Nikon for and what other Nikon products you own; also state that if you must buy another lens that your money will instead go to one of their competitors instead and that when you replace your camera you will think hard before purchasing from Nikon again. It also helps if you tell them that you were well aware that you would be charged for any repairs caused by misuse, such as dropping your lens, and so would not have bothered to try and claim under warranty under such circumstances as it wasn't worth the risk of having to pay a big bill just to get a broken lens returned to you. Tell them that you have not dropped the lens and so you dispute their findings, and at the very least request that the lens is returned to you without charge so that you can get the lens examined by an independent repairer.
As long as your letter is polite, factual and states your argument clearly then you maximise your chances of getting them to revise their position to give you the benefit of any doubt.
Good luck.
Posted on Mar 11, 2010
Testimonial: "Good honest reply and very constructive ideas for what to include in a "polite letter of complaint"."
6ya staff
SOURCE:
Sticky zoom ring on a Nikkor 18-55 AF-S Zoom. The zoom gets jerky at the 18-24 mark. I think it needs some lube but I don't know where to put it?
You would have to disassemble the lens barrel to get to the zoom sliders, and lubrication is not likely the problem anyway. The zoom mechanism uses nylon bushings sliding in a groove, and zoom problems are usually due to wearing/cracking of those bushings.
If it's still in warranty, send it in. Otherwise, the cost of repair probably exceeds the value of the lens. Sorry.
Aug 05, 2013 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Where is the reset switch of nikon d40 camera ?, how to reset camera?
There're actually two buttons. Press and hold the Info and zoom-in buttons (both marked with a green dot) for more than two seconds.
Full details are in the "Two-Button Reset" section of the manual (page 38 in my copy). If you need a manual you may download a copy from here.
Jan 08, 2013 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
Please Help. I have a Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX. I occasionally remove the front lens element assembly to clean the inner lens element as it gets dusty. The front lens element assembly...
Hi,IF I were you I will search the eBay for a same lens as " parts only " which means lens does not work but you can use the some parts of it ..There are a lot on ebay..one example is below URL..pls visit both..
Brand name services always do this..Since you were doing unauthorized repair ,they do not like it..
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Item condition:For parts or not working
http://cgi.ebay.com/Nikon-Nikkor-18-200mm-ED-AF-S-3-5-5-6-READ-/200635517251?pt=Camera_Lenses&hash=item2eb6cf0943
parts;
http://photography.shop.ebay.com/Lenses-/3323/i.html?_kw=Nikon&_kw=parts&_dmpt=Camera_Lenses&_stpos=&gbr=1
Jul 29, 2011 | Nikon Zoom-Nikkor 18-200mm f/3.5-5.6G...
My Nikon 18-55 mm lens turns easy when zooming in, but is stiff when zooming out. There is no roughness in the movement that would suggest dirt.
hi there,
the zoom-rubber might have been loosen, so it moved too easy while you use it
you can fix it by contacting nikon representative technical support
thanks
Dec 12, 2010 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
On a new Nikon 18-55mm AF-S DX Zoom - Nikkor f/3.5-5.6 lens and a Nikon 55-200 mm AF-S DX Zoom f/4.56 lens is VR also included and standard?
Nikon currently lists two 18-55 AF-S DX and two 55-200 AF-S DX lenses. One in each pair has vibration reduction, the other does not. The ones with VR in the name have it, otherwise it doesn't.
VR isn't exactly an option. If it wasn't built into the lens initially, you can't add it later. A lens either has it or it doesn't, though if a lens has VR it can be switched off.
Aug 30, 2010 | Nikon Cameras
Nikkor 18-200mm VR lens does not autofocus any more. Has worked fine but suddenly stopped working. Please help?
Hello. First of all be sure that the lens and the camera are set to autofocus. If that doesn't solve the problem for you, turn on the camera, go into the menu and find the reset function. Reset the camera, what this will do is simply take the camera to all of the factory settings it had when it was new out of the box. J.
Jun 16, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Hi, can tell to me why my 18-200 af vr lenss go
The "problem" is that the lens has a zoom creep issue. If you are the original purchaser, and the lens is under 5 years old, you may want to contact Nikon repair facilites in Melville or El Segundo to have it checked out.
Some users on forums have claimed that Nikon fixed the plastics ring that contribute to the zoom creep. Apparently, using a rubber band around the zoom ring will minimize the problem.
Hope this helps,
Andrew
May 14, 2010 | Nikon D80 Digital Camera with 18-200mm...
VR working continuously on 24-120 Nikon Lens
The VR ring as came lose...you have to send it in.
Mar 22, 2010 | Nikon 24-120mm f/3.5-5.6G ED-IF AF-S VR...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens Logo
2,346 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
