Hello, I have a problem with my Oki B4100. After I removed the sheet after a paper jam it's now constantly blinking with the error LED (red) and won't print anything. In Windows it shows the printer is ready, when I send something to print windows tells me it is printing but the printer just stays still and blinks with that red error light. I've tried turning it off and on again, tried removing the cartridge and putting it back again. No luck.
What can I do ? Am I missing something?
I have a HP K500 officejet.. Paper had been jammed in the printer and was removed.. the green light and the red feed light keep flashing in unison, shows that things have been sent to the printer but nothing is printing... could there be paper lodged anywhere where i cant see with my eyes, ive taken the back cover off lifted the lid and removed everything that my eyes can see.. ive spent hours searching for any missed paper but cant see any... please someone help before i throw it through the window!..
lights blinking,no paper jam visible,windows says printer ready.But it aint!lights blinking,no paper jam visible,windows says printer ready.But it aint!
AnonymousFeb 03, 2009
error led blinking after paper jamerror led blinking after paper jam
AnonymousMar 22, 2014
my printer is showing error 51.20 and hence cannot print. when i shoot the print command, the printer tries to lift the paper, and then the error shows up. Please helpmy printer is showing error 51.20 and hence cannot print. when i shoot the print command, the printer tries to lift the paper, and then the error shows up. Please help
You can't post conmments that contain an email address.
Re: Error LED blinking after paper jam, won't print
Hi lorraine3 -
I hope you didn't 'throw it out the window!' just for a future quick ref, here are a couple fast links to hp support docs about paper jams and blinking lights that might help:
If printer Leb is blinking then you have error in printer check the mention below note.
1) Check the printer door, all door close the properly 2) Check the paper Jam, remove the jam paper. 3) Check the cartridge level, change the cartridge.
The rightmost LED is the Error light. How fast is it flashing?
If the light is flashing 1 long flash every 4 seconds (no other lights flashing), then either the image drum needs to be changed or the toner is low.
If the flash is one blink a second, then you have a paper problem or a cover open.
If you installed the OKI software with the driver, you can use the Printer Status monitor to identify the problem and order the consumables if you have a slow blink error. (Open the printer control panel (Start >Programs > Status monitor) and Maximize the window to see the Printer status.
Acording your explained you need do
1) clean the input tray roller surface, to make sure it has enough grip force.
2) looking for a sensor around the roller rear, it could be cause the paper jam there, because if the sensor does not detect any input paper go throug there then should be stoped at roller rear.
3) if you find a optical sensor there, please use a slft cotton stick to clean its surface. (maybe open some cover needed)
hope you fix it , ask me any time please!
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
I have a similar but different model B4300. Several others, & I have found that a small piece of paper 1/2 square may lodge under a plastic guide, holding open a switch. This is very difficult to notice if you don't know where to look.
Open top lid
Remove the ink cartridge/roller drum as a single unit.
Look in the printer at the metal roller in front.
A Plastic strip on top & in front of the roller covers 2 square holes which should look dark. On your LEFT, as you face the unit, there is a small magnetic switch, to the LEFT of the LEFT square hole, under the plastic.
In my case, the paper was seen as white in the hole, and extended under the switch. I was able to grasp it with a small medical forceps, next to the switch. By gently twisting, I pulled it out without taking the unit apart.
The printer then worked perfectly after the paper under the switch was removed.
U can have stuck a little piece of paper, that it mess whit some sensor. Try to open the Oki, push the drum unit out and watch if there is no paper stucked.
If your oki is like the 4300 we use it may be as simple as making sure the extention for the back tray (where the paper is printing to now) is pushed all the way in. This actually selects the tray option. If this tray extention is pulled out at all, your printer will print to the back tray.
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Try to force a sheet into the feeder in order to clean and possible remove any piece of sheet. I had the same problem error 380: paper jam in oki 5300, but this time it said to open the front cover...
