My samsung lcd tv when i turn it on has a light black blurr down the center and a solid black bar about an inch wide on the right hand part of the screen, from top to bottom, but the weird thing is 10mins after i turn the tv on it dissappears most of the time it stays away, but sometimes comes back
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
No it sounds more like a problem with the LCD controller(or LCD panel). Can you please get me an image so that I can have a look? You can upload it to http://www.imagehousing.com/ and get me the link.
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
hi... It sounds like an Intergrated Circuit (IC) has fried. Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
