If you are logged in, sign out of Skype using File | Sign Out. If you are not logged in, you can immediately click on the link "Don't have a Skype Name". Follow the on-screen wizard to finish setting up a new account.
Hope this helps you out.
HI
YOU CAN MAKE HOW MANY SKYPE ID THAT YOU WANT
YOU MAKE THEM LIKE YOU MADE THE FIRST ONE
JUST PUT A NEW ID
YOU CAN EVEN KIP YOUR OLD PASSWORD !!
SAMUEL
http://www.rylwy.com/
Just log out of Skype and Start A New Account from there. Auto log in feature of windows will want to fire up both accounts so make sure your Passwords aren't in conflict.
SOURCE: i want to creat new skype id
I got your answer from: https://support.skype.com/en-us/faq/FA829/How-can-I-run-two-Skype-accounts-on-the-same-computer
In order to use more than one Skype account on the same computer at the same time you need to start a new instance of Skype:
"C:\Program Files\Skype\Phone\Skype.exe" /secondary
If you get any error messages, please copy and paste the exact command from this email and try again.
Please keep in mind that if you have changed the installation path for
Skype then you need to enter the correct path for the Skype.exe file.
If this solution fails, you can try another option:
For Skype 3.8 and earlier
Requirements: Windows XP, Two Skype User accounts
First, create a new Windows user by going to the Control Panel and clicking on User Accounts. Choose Create a new account
and follow the steps to set permissions. We also suggest setting a
password for the new user by clicking on the newly created user and
choosing the Set Password option. The new user will also require admin rights on your PC.
Next, create a shortcut to Skype or make a copy of the shortcut that is
already in the Start menu. Right-click this new shortcut and choose Properties. On the bottom of the first page there is a button labelled Advanced... . Click this button and select Run with different credentials. Select OK, and then select OK again to close the Properties dialog.
You're all set. Whenever you use this new shortcut it will ask for a
Windows username and password. Enter the Skype Name and password of the
user you created earlier by choosing The following user: option. Click OK and you'll have a second instance of Skype. It will require that you sign in with your Skype Name and password the first time.
To help automate the Run as trick you can create a second desktop icon for Skype and modify its properties. Click the Advanced button and check the box Run with different credentials.
After clicking on the modified icon it will ask you to sign in as
another user. Changing the icon graphic also helps ensure you click on
the correct icon.
If you have multiple USB headsets or USB Phones you should be able to
set up both instances of Skype to use a different sound device.
SOURCE: i want to creat a
you cant change your skype id you have to create another account with a new skype name
*lights cigarette*
Please visit the link below and follow the instructions
How do I create a Skype account?
Getting started with
Skype (Windows)
Hope This Information is Helpful.
Regards,
Tamim
yas
