Samsung SYNC SGH-A707 Cellular Phone Logo
Posted on Mar 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I purchased a sim card from tmobile to replace my att simcard on my samsung SGH-A707.The new sim card won't work,it sy's incorrect sim and networt lock.
Anonymous
Level 3:
Genius:
  • Master 1,456 Answers
  • Posted on Mar 10, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1456
Questions
0
Helped
475596
Points
4013
Hello
The sim wont work because it is locked to the att network which means it will only work with att sim cards.
You will have to unlock the phone from the att network before it can work with the T mobile sim card
You should contact your network provider so as to get steps to unlocking your phone from the att network or you should contact a repairer to help you unlock it
Thank you for visiting fixya
1helpful
How do I unfreeze my att samsung eternity without a computer cord
Computer card Unlocking is very Big process,So that You can use the Unlock code....also in computer card Unlocking you need to use Cable,Software,USB port,Boxes etc,so take big time ,it's risk process,cost High also,So that i would suggest the Unlock code the simple method to Unlock Your Samsung SGH-A707 SYNC phone,You need to Unfreeze means specify the Network ,Country it locked now?
You can get the Unfreeze Code at
Simpleunlocking and Unfreeze the Phone from Lock...
Samsung SGH-A707 SYNC Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung SGH-A707 SYNC mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A707 SYNC mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-A707 SYNC with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A707 SYNC is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A707 SYNC.
Each Samsung SGH-A707 SYNC mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A707 SYNC mobile phone using the form above.
I want to use my att sim card in the Tmobile phone model SGH T-239,it says wrong card. how do I unlock it so i can use the phone...pls. help...my service provider is AT&T, I removed the sim from the...
Important: Stop if you receive an error message. The device may lock permanently if you enter the incorrect code multiple times.
  1. See if your phone is eligible to unlock: Mobile Wireless Device Unlocking.
  2. Contact Customer Care to request the Mobile Device Unlock code for your phone.
  3. Verify the IMEI by typing *#06#.
  4. Insert a Non-T-Mobile SIM & turn the phone on.
  5. The phone will automatically prompt you to enter the code into an empty field.
  6. Click/Tap in the empty field above the "Unlock & Dismiss" options (this will display a key pad on the screen).
  7. Input the unlock code provided by T-Mobile.
  8. Click/Tap Unlock.
  9. The phone will display Network Unlock Successful.
3helpful
Mms settings for tmobile on unlocked att samsung eternity
follow this link and info
  • http://forum.xda-developers.com/archive/index.php/t-274193.html
1helpful
I don't have a cord to get files to and from my phone.
 I purchased my data cable for my A707 on ebay for .99c. It works great. You will have to go to the Samsung website and download the software for the Sync. Or you can purchase the flash drive look a like where you place your memory card in it and then you can put your songs on it. By memory card I do not mean your ATT sim card. Some people do not know the difference that it why I am stating that here.
2answers
Network Lock on Samsung Sync A707
Try #7465625*746*Code#
Enter the code you got from AT&T.
See if it helps.
Please ask for any clarifications
Please rate the solution as FixYa if found useful.
Thanks
Rylee
Emergency call only
give phone a reset.....or change network settings..
Samsung SIM card issues!
you dont have to buy new sim...go to your nearest service senter. hardware failure.... sim sockets or sim ic... thats the problem...
2helpful
2answers
Sim card transfer
depends on the phone you are using to transfer from. On my sony, for example, i can go to my contact list options and send contacts via bluetooth to another device.
Which phone are you sending from?
Samsung Sync SGH-A707 Audio Problem
Two things:
Are you in an area where they are upgrading the towers to 3g service? Are you going back and forth from Edge service to 3G service. That could cause the click.
And one more thing you could do is pay 25.00 to get a new sim card. Believe it or not this helps sometimes.
Other than that I do not know of any solution or why it is doing that, it should not do it. If its under warranty have att send you a new one (warranty good for a year from the date you bought it)
CARTEEUSMC
Problem regarding mobile sim card chang
Your phone is asking for a code because it is locked to only work with one phone company. If your new sim is from a different company, you can request the unlock code from your old company, they may or may not give it to you (tmobile usually does, ATT/Cingular usually doesn't). The other option is to use a unlocking service, you can find plenty on ebay. If you didn't change phone companies, your new sim card is most likely bad, have your phone company send you another one.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
