I have a Primo 1800 shredder. I understood that the shred size depends on cutting type. So, tell me please, how can I choose between cross cut and strip cut?
Re: How can I choose between cross cut and strip cut?
DEPENDS ON THE SECURITY OF THE SHREDDED DOCUMENTS YOU WANT.
A MEDICAL OFFICE WOULD NORMALLY HAVE A CROSS-CUT SECURITY SHREDDER SO NO-ONE CAN PUT DOCUMENTS BACK TOGETHER..ALSO BANKS AND LAW FIRMS.
A STRIP CUT SHREDDER CAN BE PUT BACK TOGETHER IF YOU ARE DETERMINED ENOUGH.
The HSM Securio B24 is a high-security paper shredder that is designed to shred sensitive documents into extremely small particles to protect against identity theft and other types of data breaches. It is capable of shredding up to 24 sheets of paper at a time and can also shred staples, paper clips, and credit cards.
To use the HSM Securio B24, you simply need to place your documents in the feed opening and push them through using the built-in handle or the manual feed. The shredder will then automatically shred the documents into small particles that are difficult to reconstruct.
The HSM Securio B24 also features an automatic start/stop function, which means that it will start shredding as soon as you insert your documents and stop when you are finished. It also has a reverse function that allows you to easily remove any shreds that may be stuck in the shredder.
The
frequency of shredder oil applications is determined by a number of
factors. First of all cross cut shredders must be oiled more often than
strip cut shredders do. A cross cut paper shredder
will require regular applications of shredder oil while a strip cut can
go for a longer period of time without decreased performance. Secondly,
paper shredders that are used more will need more lubrication. A paper shredder
under heavy usage will need oil about once every four hours, while one
under normal use will only require oil once or twice a month. Most
manufacturers recommend oiling the cutters once every 30 minutes of
accumulative shredding, but an easy way to remember is just to oil your paper shredder
every time you change the bag. The type of material as well as amounts
fed at once can also effect performance and lead to the need for oil.
Directions You should only use specifically designed shredder oil to oil your paper shredder.
This oil is designed to lubricate precision heat treated shredder
cylinders, and any other lubricant or oil will void the manufacturers
warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The
first way to oil your shredder is to spray or squirt lubricant into the
opening and onto the cutting heads. The oil is packaged in a squeeze
bottle and is applied directly onto the cutting head in a fine stream.
This is done through the paper entry throat. Take 1-2 seconds to oil
from one side of the opening to the other. Turn the machine in reverse
for about 10-15 seconds to allow the oil to transfer to all parts of the
cutting head. The final step is to shred a few sheets of paper to
remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder
is illustrated in the image above. Simply spread a small amount of
shredder oil onto a piece of paper in a zig-zag type motion. Make sure
that you spread the oil over the entire sheet. (NOTE: you don't need to
soak the paper in oil, just ensure total and even coverage.) Feed this
sheet through the shredder and then operate the machine in the reverse
mode for a few seconds. This will make sure the oil is dispersed
throughout the shredders cutting cylinders. The final step is to shred a
few sheets of paper to remove any excess oil. You may want to repeat
this procedure depending on the results, and is recommended for up to
three applications to be assured of thorough oiling.
You should
oil your cross cut shredder on a regular basis. If you are shredding a
small quantity such as only 50 sheets a week or if you are using a small
shredder, then you should oil your shredder every other day. If you are
shredding a large quantity such as hundreds of sheets, then oil after
30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
The frequency of shredder oil applications is determined by a number of
strip cut shredders do. A cross cut paper shredder will require regular
applications of shredder oil while a strip cut can go for a longer
period of time without decreased performance. Secondly, paper
shredder under heavy usage will need oil about once every four hours,
while one under normal use will only require oil once or twice a month.
Most manufacturers recommend oiling the cutters once every 30 minutes of
paper shredder every time you change the bag. The type of material as
well as amounts fed at once can also effect performance and lead to the
need for oil.
to oil your paper shredder. This oil is designed to lubricate precision
heat treated shredder cylinders, and any other lubricant or oil will
void the manufacturers warranty. So don't use WD-40 or the like to oil
The
oil your paper shredder is illustrated in the image above. Simply
spread a small amount of shredder oil onto a piece of paper in a zig-zag
type motion. Make sure that you spread the oil over the entire sheet.
(NOTE: you don't need to soak the paper in oil, just ensure total and
even coverage.) Feed this sheet through the shredder and then operate
the machine in the reverse mode for a few seconds. This will make sure
the oil is dispersed throughout the shredders cutting cylinders. The
final step is to shred a few sheets of paper to remove any excess oil.
You may want to repeat this procedure depending on the results, and is
recommended for up to three applications to be assured of thorough
oiling.
You should oil your cross cut shredder on a regular
basis. If you are shredding a small quantity such as only 50 sheets a
week or if you are using a small shredder, then you should oil your
shredder every other day. If you are shredding a large quantity such as
hundreds of sheets, then oil after 30 minutes of usage or after you
empty the bag.
Nearly impossible to find at a price that will make it worth it unless your planning to buy them in bulk from a distributor and do this type of repair often.
Asking why you should keep your shredder lubricated is no different than asking why you should change the oil in your car every 3,000 miles. Not only is proper maintenance a requirement to maintain an active warranty, but all mechanical parts need a little oil to help them turn smoothly and to keep them clean. Applying shredder oil to the cutting heads inside a shredder lubricates them so that they efficiently destroy documents sheet after sheet. Fortunately, you will find that taking good care of your shredder is less expensive, faster and easier than caring for your car.
Every time you shred a sheet of paper a fine dust made of tiny paper particles is produced. This dust collects in the cutting assembly of a paper shredder. If allowed to build up, this dust will compact until it completely blocks the smooth turning of the cutting head. Shredder oil will actually break up the compacted dust lodged in the cutting assembly, allowing the parts to move and push out the softened dust.
Shredder oil is specially formulated to eliminate oil residue on the cutting head. Other oils, like WD-40, will attract dust, further clogging the cutters. When lubricating your paper shredder, only use oil specifically designated for shredder use or risk voiding your warranty and further clogging your shredder.
The frequency with which you should oil your shredder depends on several factors: frequency of use, shredder capacity, cut size and type of paper. Your shredder will need more oil the more you use it, the more paper you shred at once and the thicker the paper is that you shred. Also, shredders with smaller shred sizes require extra oil. A 1/4" strip cut shredder used only one to two hours per week will only require a weekly oiling. A cross cut shredder, on the other hand, requires oil after every half hour of use. If you remember to oil your shredder every time you change the bag you'll be in good shape. There are two fast, easy ways to oil a paper shredder:
The first method involves applying the oil directly to the cutting head. Shredder oil is packaged either in plastic squeeze bottles or aerosol cans, designed for easy application. No tools are required, just aim the bottle directly at the cutting head, through the paper entry point, and apply a fine stream of oil from one end of the cutter to the other. Run the machine in reverse for 10-15 seconds until the entire cutting mechanism is coated. Finally, shred a few pieces of paper to remove any excess oil from the cutters.
The alternative method requires streaming oil onto a piece of paper. Do not soak the sheet in oil, but cover it evenly from edge to edge. Shred the oiled sheet of paper and then run the shredder in reverse for 10-15 seconds to allow the oil to coat the entire cutting mechanism.Finally, shred a few sheets of paper to remove any excess oil from the cutters.In any case, run a couple of sheets of paper through the shredder after oiling to remove excess oil.procedure may be repeated up to three times to ensure proper lubrication.
If you take a few seconds once a week or every time you change your shredder bag to oil the cutting mechanism in your paper shredder, you'll maintain your warranties and keep your shredder running smoothly and efficiently document after document.
click this link directly for more detailed help
---- http://www.howtocleanstuff.net/house/appliances-and-fixtures/how-to-clean-a-shredder/ --------
thanks.please do rate the solution.thank you for using fixya.keep updated.
try shredding a old card, carefully but forcibly push the jammed plastic strip through the teeth. might be faulty alignment of teeth, a factory defect!
