Brother CS6000i Computerized Sewing Machine Logo
Posted on Mar 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brother CS-6000i - the bobbin thread is not coming through in order to make a stitch. I have cleaned the bobbing case, changed needles, re-threaded machine, changed thread, and even changed bobbins. It was working fine the other day. Suggestions? Thank you.
Anonymous
Level 3:
Genius:
  • Master 1,116 Answers
  • Posted on Mar 10, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1116
Questions
0
Helped
371332
Points
3174
Check list:
1 - Flat side of the needle is facing the back of the machine.
2 - Threaded machine with the presser foot up - always.
3 - Bobbin thread is feeding from the spool in the correct direction and through the proper guides.
Lower and raise the threaded needle, holding onto the end of the thread.
If this does not pull the bobbin thread up, the timing may need adjusting.
There is a graphic for doing this as sewusa.com or take it into the dealer for service.
2answers
I have a Brother CS-6000i sewing machine. My straight seams pull out just by pulling the thread. Like basting! How can I get a seam that locks.
indicates that the needle thread tension is not tight enough
make sure that there is thread in the bobbin
My brother cs-6000i computer sewing machine shows a E6. I cleaned around the bobbin and checked the needle. I replaced the bent needle and it still does the same thing "E6". What will fix this?
Follow the instructions below if you receive the error message "E6"
1. Check if the machine rattles and stops as soon as the sewing starts
- Upper thread could be tangled or threaded incorrectly
- Check that the thread take-up lever is threaded
- Raise the presser foot to raise the needle to its highest position and re-thread the machine
2. Remove the bobbin and bobbin case
- Clean any lint or loose threads
- Install the bobbin case so that the projection on it aligns with the spring and install the bobbin into the bobbin case
3. The needle could be bent
- Check that the needle does not hit the needle plate
- Replace the needle if necessary
- Make sure the flat side is facing the back
If the problem persists, your machine may require service.
If the machine is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the machine is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
https://help.brother-usa.com/app/answers/detail/a_id/54048/~/error-message-e6
1helpful
2answers
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Bobbin thread shows
have you tried to tighten the bobbin tension spring??
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
I am using my Brother CS-6000i sewing machine for the first time and keep getting the E6 error code. It worked fine for the first 2 rows of stitches I did then I got the error and the thread was tangled. I...
What kind of thread are you trying to use? Is it a decent fresh thread? If, it is old, throw it out and buy some fresh quality thread. Usually, cheap thread is the problem.
4helpful
Unable to adjust tension,
Sounds like the bobbin thread is not inside the tension on the bobbin case. This normally happens when the bobbin is upside down. Insert the bobbin and pull on the thread.The bobbin should turn counter clockwise.
sewman7
Brother CS-6000i
I have the same problem but I believe the answer is to purchase a new shuttle which is the part the bobbin sits in and is most likely scratched or damaged. The quote I got was 40-50 dollars
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
