You need to find out the spec on the A4 photo grade paper.
If the paper is to heavy, then it will not pick and feed properly. If the paper is to glossy, it could cause the paper to slip and smudge or blurry the image.
If the paper is made for a laser printer, the ink will be absorbed into the page.
Laser printers fuse (heat and pressure) the image onto the paper. Ink printers, however, require that the paper be able to absorb the ink into the paper.
Don
