Games for my PS3 will only play when i first switch my console on
My PS3 wont read the disc if i eject the disc and insert a new game into my console.i have to insert the disc then switch of my machine for approx 30\60 minsiit always reads dvds only has problem reading games that arent installed on my harddrive. it a old phat PS3
The most common reason for the Wii not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!!!!!!!
Hi, The most common reason for the game not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
The most common reason for the games not reading discs is a bad drive.
This
The most common reason for the PS3 not reading discs is a bad
This
the entire DVD drive assembly mechanism replacement for your PS3
what you need to get your PS3 going again! Hope this will help...
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again! Hope this will help...
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The most common reason for the PlayStation not ejecting
Normal
0
false
false
false
font-size:10.0pt;
This drive should fix any issues inserting your games or ejecting them (or
your PlayStation including a new laser. If your discs are not ejecting, or you cannot
you need to get your PlayStation going again!
have the sony turned off then before turning it on place your finger over the eject button then turn the console on with your finger still in place this is the eject override method it should spit out your disc if not u may have other hardware issues
Short answer its a ..... to fix. Theres multiple lasers in the disc drive that actually read the disc. The blue laser failed. Replacing the drive wont work unless you can reprogram the eeprom chip (or is it nand?) At any rate its just better to upgrade to a new console.
