Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My SHE4402UC/36 dishwasher malfunctioned all the lights were flashing and the machine was trying to drain. The guy came out and replace the control board. The dishwasher now read 199 on all cycles except the rinse and hold, the santitized light does not come when its done. The repair guy told me the count down timers were flakey on the the Bosch dishwashers and it would learn my dishwashing patterns in time. So 6 cycles later the dishes are still damp at the end of the cycle-the length of the cycle and the dispaly are out to lunch and the dishes are not hot to touch at the end of the cylce. will my unit learn these patterns or is that baloney
Anonymous
Level 2:
  • Expert 457 Answers
  • Posted on Mar 15, 2010
Anonymous
Expert
Level 2:
Answers
457
Questions
Helped
126588
Points
799
Well its not baloney but it is cheesey. normally changing the module is the cure but it has to be programmed correctly. bosch has a recall so check it out and see because the recall is free and the tech is suppose to know how to program it. go to thermedor .com and get the #. i am a old bosch tech.
Miele G892 SC dishwasher stops 5 minutes after starting with flashing inlet/drain light. The drain is working because it drains at the beginning. Water is also coming in. None of the holes in the spray are...
If your Miele G892 SC dishwasher is stopping 5 minutes after starting with a flashing inlet/drain light, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
  1. Check the water pressure: Make sure that the water pressure is within the required range for the dishwasher (between 1.5 and 5 bar).
  2. Check the inlet hose: Make sure that the inlet hose is not kinked or clogged.
  3. Check the water inlet valve: Make sure that the water inlet valve is not clogged or malfunctioning.
  4. Check the water level sensor: Make sure that the water level sensor is not clogged or malfunctioning.
  5. Check the control board: Make sure that the control board is not malfunctioning.
  6. Check the temperature sensor: Make sure that the temperature sensor is not malfunctioning.
  7. Contact Miele customer support: If you have tried all the above steps and the dishwasher is still not working, it may be best to contact Miele customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Miele G892 SC is an older model dishwasher, which makes it harder to find replacement parts and professional repair services.
1helpful
Start light flashing,rince light on.machine will not start cycle
Hello. I really need the make/model number to help you accurately. However, from the symptoms you're describing, it sounds like the drain pump is jammed. A lot of dishwashers turn on the drain pump first to remove any stagnant water sitting in the bottom of the pump. Then, fresh water is let into the tub, fills to the proper amount, then the main pump starts. The lights flashing are an error code--different combinations of buttons flashing mean different things. On some models, a button light will flash a certain number of times, pause, then flash another number of times. This is a binary code telling the user what is malfunctioning. That's why I need the model number and any other info to help diagnose the issue. Thanks!
Sep 18, 2015 • Dishwashers
Flashes on the start button
Hit the cancel/drain close the door if light or start light flashes door switch is bad.
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
IF THE MACHINE START IT SHOWS FLASH AFTER 2min
test this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 22, 2013 • Dishwashers
Flashing indicator light
follow the next steps and fix it. God bless you
Check Fault Codes
Drain Pump
Touchpad
Jul 06, 2013 • Dishwashers
2answers
Have a Miele G1022i dishwasher (built in). It makes a humming noise when the power supply is turned on. All the indicator lights flash. Have tried cleaning out the drain and removed water from the salt...
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced.
Gene
Aug 05, 2011 • Dishwashers
Dishwasher won't start
Replace the control board, or...if you're capable, resolder the control board joints for the wire connectors and the relays.
That fixed mine after I wasted money on a heater.
Dishwasher not responsive, just a blinking CLEAN light.
HI, this is a control fault that is located in the logic sector of the circuit board. You will need to replace the control in order to restore proper function.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
