Have you forgotten your mobile password? Try default security code for your mobile. It doesn't work simply reset your mobile.
You can easily reset your mobile by using master reset code. If you need master reset code you can visit this site Unlock-free.com
here you can get the code and reset your mobile easily. Unlock-Free.com
When Factory Reset is performed, the setup value will factory default setting
When initialization starts.
1.Select System Setup from Menu Screen.
2.From the System setup submenu, Set Factory Reset to ON
3.When you exit Menu, The phrase FACTORY RESET Appears on the monitor and
The Initialization starts.{ON/OFF} Use arrows UP-- DOWN & , kEY TO MAKE CHANGES
HOPE THIS HELPS
Try this .
Cut the SMT-190Dx off using the switch. Let it stay off a few seconds and turn on again. In doing so, the unit's password will resort back to it's default both login and password. Then you can go back in and reset it to whatever you like.
There doesnt seem to be a code for this model. but follow this instruction hopefully it will help.
Just talked to Samsung regarding Reset procedure. Simple: Press CH2 and Alarm buttons on receiver at same time for 10 seconds. It will reset to factory.
Hold the remote control's STOP ( ) button for
longer than 5 seconds. “INITIAL” appears on the display and
all settings will return to the default values.
• Press the POWER button.
Using the RESET function will erase all stored settings.
Do not use this unless necessary.
