Brother MFC-7340 Status monitor says offline. Scanner works to the computer but it wont print from the computer.
Its a new printer loaded on a vista 32 bit machine.
I have loaded the disc software, tried the latest drivers from brother and the usb specific drivers.
I can copy and print at the machine so I think it is printer driver related.
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
SOURCE: How to take out brother tn 330 toner
You open the front door and pull out the drum and toner assembly and then press the blue lever to release the toner from the drum, place the new toner in the holder and install both together into the machine.
SOURCE: BROTHER MFC-7340 DRUM ERROR PROBLEM
Commonly caused by High voltage discharge or arcing from a dirty primary charger corona and grid.
You need to clean your drum unit.
Open the front door and pull out the Drum unit.
Look on top of it for a small (usually) blue slider, sitting in a 10mm slot that runs the length of the Drum unit. This is the corona cleaner.
Slide this back and forth about 6 times, ensuring you return it to the original starting position.
Reinstall the Drum unit and try printing.....
SOURCE: Need service manuals
You can access all of Brother's printer manuals online at their website in .pdf for free. Just go to http://www.brother-usa.com/manuals/default.aspx?PGID=5&R3ModelID=DCP165c and find your printers; you don't even have to download them.
Brother and its logo are trademarks of Brother Industries, Ltd., Japan. All specifications are subject to change without notice. All registered trademarks referenced herein are the property of their respective companies.
