You did not specify which lights are on?
- The green pilot light will illuminate to show that the appliance is switched on.
- The red alarm light will also illuminate until the freezer
reaches the correct temperature.
- If you press the SUPER button than you start fast freeze function and yellow light will illuminate.
I assume that the freezer is on and the green light is illuminated. This means that the freezer is on and energized.
Also, if freezer does not cooling, means that did not achieve the set temperature should be illuminated the red light (alarm).
Set the thermostat for example in position 4th and after that compressor should be start.
If compressor running but not cooling, defective is the system which circulates gas.
If compressor does not start, then is faulty thermostat, compressor or the wiring.
Dado
