SOURCE: Can not install printer software. Goes through
You need to remove the software completely to avaoid getting conflicts when installing back the software
Follow the basic steps
1) enable show hidden files and folder
2) delete C:\Documents and Settings\All Users\Application Data\Kodak
3) delete C:\Program Files\Kodak
4) run clear again at www.kodak.com/go/clear
5) reinstall the software at www.kodak.com/go/downloads
SOURCE: My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
SOURCE: purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Testimonial: "Hi - the printer was caput - had to be replaced. Thank you for help."
SOURCE: My Kodak ESP 3250 won't
Try initiating the scan from the computer, once you plug in the USB cable into your computer, go to My Computer, right click the sanner (should be called something along the lines of KODAK ESP.....) and press scan, then click which program you'll use to scan it, I usually do the Microsoft one, Good luck!!
