If you have an AV Video Audio Out on the camera, as I suspect you do. Then you can get a USB Video/Audio Capture device, OR a PCI TV/Video capture card, (Best) and using that you can "Stream" the video over this link to the PC and save it as a Video file,say MPG4 or the like. This gives great results and is easy to do. You simply connect up the camera, start the Video capture software, and press Play on tape, so to speak, then you will be able to capture the video,and save it as you wish, then you can burn a DVD or send it to someone else. Otherwise you can get USB to Firewire converters and you can use that too. But you will still need the same video capture software and such. Dscaler is a great recording software.
