SOURCE: Olympus FE-130 will NOT focus
It sounds like the focus motor in the lens is jammed. This could be caused by a knock or possibly sand. You could try tapping the camera (not too hard...). This might free up the motor the only other solution is to take it to a shop.
SOURCE: FE-280 Wont Focus and Shust Off
I have the same problem, but my display doesn't show anything. It is just black.
SOURCE: Autu focus
Best thing you can do is focus manually, using the little green dot in the bottom left hand corner of the viewfinder for assistance.
The 'lag' is due to the camera deciding the focus point, passing it to the motor in the lens, by which time the subject hs moved and so it tries to fix again by moving through the range.
Its annoying, but focusing manually, although not a solution per se, is the only option.
Sorry mate.
SOURCE: E-volt 500 Olympus camera will not work well on most settings.
Turn the camera mode dial to P - press Menu button - camera 1 tab is highlighted - right arrow over to Card Setup - down arrow to custom reset setting - right arrow to reset and press Ok - highlight Yes and press Ok. The camera should be back in factory defaults.
SOURCE: Olympus 550 UZ battery
I have been using energizer lithium batteries, and get well over 500 pictures (mixed flash/no flash)
