Exercise & Fitness Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My treadmill belt just stopped, message error E
My treadmill belt just stopped, message error E 1, manual says deck oil and check sensor position -- where is the sensor.
thank you
John Mazmanian
Level 3:
President:
  • Cardiozone Master 832 Answers
  • Posted on Mar 13, 2010
John Mazmanian
Cardiozone Master
Level 3:
President:
Answers
832
Questions
0
Helped
628608
Points
2056
Unplug your unit, then remove motor shroud have a good light the sensor is either mounted on the frame by the front roller/pulley unit or it is mount on the motor sometimes by the flywheel sometimes on the opposite end. Next step is to locate the motor control board and plug you uit in. Your board should ligt up with red ,green, or amber L E Ds now manually move the running belt and you should see one of those lights flicker or not if it does then the sensor is working , then we other issues, if not either we have a defective or misalign sensor. An if your unit needs lubrication use a synthetic silcone product.
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Cybex 530t error 1
Error 1, Err1 Belt didn't start (or no speed sense) 1. Perform speed calibration procedure
2. Check speed sensor
3. Check motor brushes
4. Check drive motor
5. Check lower board
I am attaching a link for the service manual. This information can be found on page 65. You can use this manual to determine the steps required for checking the above mentioned items.
http://www.sportsmith.net/images/product_support/cybex/Manuals/Service/LT177304-CybexProPlusTreadmillOwnersServiceManual.pdf
Cybex Pro 530T Treadmill Parts Deck Belts Motor Rollers SPORTSMITH net
2answers
Displaying error 1 what could be wrong and how do I repair it?
Avanti 928 Treadmill U8 error
try to LUBE the deck belt, with silicones or wax, . If the problem persist TIME to replace the old deck board.
However, adjust The REED switch + speed sensor.. See the owner manual for to locatea. otherwise download free from
www.fitnessmanualsonline.com
God bless you
Avanti treadmill 928
firts LUBE the deck belt with silicone or wax. Read you manual. If the problem persist, TIME to replace the old deck board.
However adjust the REED swticha+ speed sensor. see your manual
God bless you
1helpful
I have just used my LIME MT9 treadmill for the first time and it keeps stopping every few minutes with an E01 error message.
lube the deck belt and proceed according. However you must readjust the speed sensor + Reed switc. Run the software calibration for easy diagnose and fix it. see the diagram attached.
God bless you
1helpful
Treadmill stops dead with error 1 showing
Step 1:
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Adjust the sensor speed see the diagram attaached, test for open or faulty. Clean it, and tight very well the connector
Step 2:
However you must LUBE the deck belt+rollers bearing see the video attached.
If the porblem persist, TIME to replace the old board deck belt
God bless you
9helpful
2answers
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
1helpful
I have the Lifecore Fitness T900HR treadmill and when my husband is running it stops. We have made sure all the connections are tight even the safety key but it still stops. When I am using the treadmill...
Their might be high friction between the belt and deck thus causing the error 1 code when your husband is on it. Try lubricating the area between belt and deck using silicone lubricant ( refer to owners manual). Then the lighter of the two "aka wife" walk on the treadmill for about 5 to 10 minutes.
This should take care of the problem if not then their is an issue with the belt and deck ( 85% of problems on treadmills are belt and deck related)
Treadmill slowing down and sticking when you put your weight on it manual says to try leveling screws but doesnt tell you where to find themalso tried oiling but this did no good
Check between belt an deck for heavy wear. (coating worn off deck or belt unraveling) Decks can be flipped usually, worn belts should be replaced. If not check belt tension. Tension adjustment bolts are at rear end caps behind tail roller. If you can step on it and stop striding belt it very well may need a tension adjustment. Also would verify it is striding belt that is stopping. Motor drive belts can cause similar symptoms. {Check Manufacturer For Proper Belt/Deck Lube ie. Wax}
Top Cardiozone Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Ojo John...
Ojo John...
Level 1 Expert
Are you a Cardiozone Exercise and Fitnes Expert? Answer questions, earn points and help others
