That is likely a bad a power supply aka high-voltage converter.
I do recommend testing or having it tested to make sure. This is done with a voltmeter. Many of these units also use relays in them which act as switches to turn on and off components of the set. These also can go bad and would need to be tested with an ohmmeter. An oscilloscope is a great tool in diagnosing electronical problems.
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
How much will it cost to get checked and fixed?
