My boss gave me his printer/scanner/fax, a kyocera 2050, i'm trying to set it up in my home office....i have the printing function working fine, but i can't seem to set up the scanner.
i can't access my kyocera km2050 printer on my local area network. i m using though switch. how can i access my printer on local area network ? i can't access my kyocera km2050 printer on my local area network. i m using though switch. how can i access my printer on local area network ?
AnonymousMar 23, 2014
copyer not clearcopyer not clear
You can't post conmments that contain an email address.
The 2050 uses 2 network connections, one for the printer and one for the scanner.
Before I go into any great detail,
Do you have a home network? Are you using a switch?
Are you printing through the network connection or the USB/parallel port?
Are you trying to twain scan? Do you have the software CD for scanning.
If not, you will need to download the drivers from the Kyocera web site.
Firmware up dates for these machines need to be done by someone with experience. There are two seperate for the machine, printer, fax, and scanner and are done differently. THe updates are provided by the manufacture to dealers that are trained to work on these machines and should not be done by others because there can be a negative outcome if done improperly, leaving your machine nonfunctional.
Use the link below to get to the manufacture's website where you can down load all the manuals for this model machine to include the fax user guide. If you need more assistance go to www.gfbm.net
The link below will take you to the manufacture's website where you can download all the user manuals for this machine and in them you will find the instructions. If you need further help go to www.gfbm.net
• The home position is not correct
when the power is turned on or copying
the document placed on the contact
glass.
Poor
contact of
the connector terminals.
Defective scanner
home position
switch.
Defective engine
PCB.
Defective scanner
motor.
the issue needs to be resolved on the other end..It's not an issue with your machine...They need to do 1 of 3 things...either setup distinctive ring with their phone company...or purchase a fax line.. or get something called "the stick"
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
copyer not clear
