Hi, The problem could be with the receiving machine and not yours. Here is a little test you can do, make a copy of a blank page and if the copy has line on it then it is your machine, if not then it is not yours. You need to open the top where the document feed through and clean the scanner glass with a moist rag, spots on that glass can cause lines.
Good luck, keep us posted.
Is this the issue for all the faxes you have sent or its just a situation, i mean a particular fax number and machine,
I hope this helps, please revert asap so i can give you a better solution, thank you for time,
